Sponsored by: CARiD
Rebuild Questions
Old Aug 22, 2001 | 05:29 PM
fully_bodykited_s4's Avatar
Rebuild Questions
What is the absolute minimum parts u need to buy from mazda to do a cheap rebuild of a 13b turbo engine series 4.
Old Aug 23, 2001 | 01:23 AM
fcturbo2's Avatar
Assuming your old side housings are not warped or overheated the least amount of parts you need are:
NEW APEX SEALS
NEW ROTOR HOUSINGS
NEW GASKETS
I recommend you put new rotor housings in if you dont want to end up tearing the motor apart again because youre not getting good compression. If side housings are slightly warped i would take it to a machine shop that has the right grinding machine (lapping) to resurface the housings. Mazdatrix charges $50 a face $200.00 for all three. New apex seals is a must!..GOOD LUCK
Old Aug 23, 2001 | 01:32 AM
fcturbo2's Avatar
BTW..rotary is not cheap. It will probably cost you more than 1K for the parts i listed above.
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
SCinfidel
Sep 8, 2015 05:36 PM
rotor_veux
Sep 3, 2015 07:10 PM
