Air Pump vs A/F Meter
Old Mar 23, 2003 | 02:05 PM
Newbie
Question Air Pump vs A/F Meter
Hi
Please can someone enlighten me.
I have a homemade a/f meter with 10 leds. 3 green (rich), 4 yellow (stoic), and 3 red (rich).
While cruising in 4th gear at 35mph ( approx 2000rpm ) my meter will be flicking between red & yellow
but then I can hear what sounds like the air pump coming on and my meter flicks to the first green led.
In my case that is the 'power led' the one the lights under WOT.
The pump can stay on a while unless you take your foot off the gas, it will then go full lean but the cycle then repeats.
Cruising at higher speeds, approx above 45mph this doen't seem to happen.
Is this behaviour normal for the air pump ??
Thanks
Puppetman..
PS> As seen in other posts, my a/f meter reads steady first green led at idle.
Old Mar 23, 2003 | 03:28 PM
skunks's Avatar
I'm a CF and poop smith
aftermarket O2 meters dont work at all! They kinda only work at WOT but even then, they dont really work. get on a wide band asap or get ready for a new engine!
13
Jan 9, 2018 11:19 AM
Frisky Arab
Sep 4, 2015 06:17 PM
rotor_veux
Sep 3, 2015 07:10 PM
