Octane
Old Mar 23, 2003 | 09:37 AM
smile444's Avatar
Octane
Hey Rexheads,
I am just curious what you guys and gals are running for Octane (Ie. what kind of gas), 87, 89 or 91?
What kind of results have you been getting with these?
Old Mar 23, 2003 | 09:38 AM
MikeLMR's Avatar
'Last Minute' Rallying
92 or 97 for me , can't tell the difference to be honest
Old Mar 23, 2003 | 10:22 AM
MosesX605's Avatar
My wife bought me 2 RX-7s
Get the lowest octane possible. Anything higher is a waste of gas, unless you've adjusted your timeing to allow for the slower burn of premium fuel. Because of the shape and size of the combustion chamber in a rotary, it doesn't need a particularly high octane in stock trim.
Old Mar 23, 2003 | 10:47 AM
AdrenalifeRX7's Avatar
Are you gonna shift?!
I use 94 octane since I'm running a turbo motor. If you're N/A and close to stock just use the lowest octane, since you won't find any performance gains using higher octane. Gas prices these days can be hard on your wallet, so be reasonable.
Old Mar 23, 2003 | 10:52 AM
MikeLMR's Avatar
I use the high octane stuff every few tanks as it has some nice fuel cleaner addatives in it ... otherwise its just straight 92 octane unleaded (lowest available!)
Old Mar 23, 2003 | 02:01 PM
Jeff20B's Avatar
Lapping = Fapping
If you add a pint of 99% alcohol to your tank, does it lower the octane, or raise it? All I think it does is slightly lean the mixture if you're running rich, but I'm not sure about the octane.
Old Mar 23, 2003 | 02:03 PM
Manntis's Avatar
add to cart
octane = less explosive. It's to prevent pre-detonation in high compression engines.
An N/A rotary is not high compression and actually works better with lower octane fuel. I use 87 octane and Pamela purrs like a kitten on the stuff.
Old Mar 23, 2003 | 02:46 PM
81Rex6port13b's Avatar
I Push My Car Real Fast!
your lowest octane is higher than our highest octane.
Old Mar 23, 2003 | 02:54 PM
specRX7_22's Avatar
please not another 4 page thread on this lol. i dont tell people this if i dont have to, but do a search.
Shainiac
Jul 17, 2019 02:20 PM
alphawolff
Nov 17, 2015 05:57 PM
Snook
Oct 4, 2015 08:47 PM
rx7brandon
Aug 16, 2015 10:55 AM
