Power FC Non-seq and PFC
Old Mar 20, 2003 | 11:19 PM
911GT2's Avatar
The Power of 1.3
Non-seq and PFC
So I'm doing the poormans non-seq in a week or so, and I just ordered a PFC. As I'm reading about PFC controlling boost in non-seq mode, I'm getting scared. Has anyone actually done this successfully?
Old Mar 22, 2003 | 12:02 PM
911GT2's Avatar
The Power of 1.3
bump
Old Mar 23, 2003 | 07:16 PM
911GT2's Avatar
The Power of 1.3
So no one has a PFC controlling boost in non-seq mode?
Old Mar 23, 2003 | 07:25 PM
twokrx7's Avatar
Need more sleep
I've not seen it work sucessfully with an open exhaust.
Old Mar 23, 2003 | 07:59 PM
911GT2's Avatar
The Power of 1.3
Well thats at least one response, thanks twokrx7
Old Mar 23, 2003 | 08:11 PM
I would like to know too because iwant to buy the pfc also. ihave the mod too and got the evc hks boost controller.
Old Mar 24, 2003 | 05:25 PM
funnyguy_11's Avatar
I went non seq with a PFC. I'm having a hard time keeping the boost down too, but it hasn't gone above 14psi. You could buy a manual boost controller. I heard that helps.
Old Mar 26, 2003 | 12:23 PM
cewrx7r1's Avatar
Eye In The Sky
I am non-seq with many mods and almost stock porting.
The Hallman manual wasn't good above 12PSI as it would spike no matter what I tried. I tried the PFC boost control, it was crap.
Now I am in heaven with a Blitz controller.
Since your question was about using only the PFC to control boost, I can not answer your question.
Old Mar 29, 2003 | 07:57 PM
Benjamin's Avatar
I just did the non-seq w/ my PFC. I've got the Profec B. It's WONDERFUL. It's exact--every time. I've got it set to .83, and the worst that will happen is that it jumps to .84 in 5th gear.
I did have the Home Depot controller for about 8 months, but it's not consistent. It will jump between .74, and .86 in the same setting, in random gears. If you don't care about that consistency, get the cheap one. If you truly want to be safe, get a good boost controller.
-BN
Old Mar 30, 2003 | 08:39 PM
911GT2's Avatar
The Power of 1.3
Do any of you still have cats? I am planning on keeping a cat in some form or another, either stock or high-flow. Anyone with a PFC controlling boost in Non-Seq form with a cat?
Old Mar 30, 2003 | 11:23 PM
Benjamin's Avatar
High-flow (they say) flows 96% as much as a midpipe, so in that case get one. You can still boost spike WAY into unsafe levels with the stock cat on there. Intake, DP, SP, CB are PLEANTY to raise your boost. The home depot one takes no time, and by the ***-dyno, it doesn't really fluctuate enough to be too terribly irritating. A lot of it depends on temperature and air density with that controller.
-BN
Old Apr 8, 2003 | 01:09 AM
racedriver's Avatar
I had 14 psi spikes with pfc stock controler, i ported the wategate ( at a machine shop) out to 1.2 inches instead of 1 inch and it cured it.
Einheri
Oct 7, 2015 12:23 PM
baix2
Power FC Forum
Sep 28, 2015 09:40 AM
RE-Mamamia
Sep 11, 2015 02:13 PM
