20b compression is 9:1 and N/A is the same
Old Mar 16, 2003 | 03:45 PM
Why cant you turbo and na 13b it has a 9:1 compression rating and so does the 20b right or not? So why is it everyone is against turboing an NA
just a question Im still learning here
Old Mar 16, 2003 | 03:53 PM
wwilliam54's Avatar
it WILL run
you can turbo an n/a engine
its just more prone to detonate
Old Mar 16, 2003 | 03:59 PM
No7Yet's Avatar
N/A 13Bs have static compressions of either 9.4:1 or 9.7:1, depending on the series.
Brandon
Old Mar 16, 2003 | 05:09 PM
rotarygod's Avatar
Rotors still spinning
Yep 8.5: or 9:1 for the turbo engines and then what he just said.
Old Mar 17, 2003 | 08:28 PM
lol... thanks guys just was curious. by the way what is static compresion mean
And cant you just put turbo rotors in it then turbo it ????
thanks for the learnign lesson thou
Old Mar 17, 2003 | 09:10 PM
No7Yet's Avatar
The stock 20B runs the same static compression as the S5 13BT, 13B-REW, and 13B-RE; thus, it's already got "turbo rotors". Some have installed S5 9.7:1 rotors and run it N/A with good results.
Static compression is the geometric compression ratio of the engine (ratio of volume at BDC to volume at TDC).
Brandon
turbodreamz22
28
Nov 10, 2023 11:08 AM
rxlevi7
Sep 26, 2015 07:28 AM
