testing injectors
Old Mar 5, 2003 | 11:25 PM
yodaddy's Avatar
Question testing injectors
how can i test my injestors to see if they are opening and closing properly? also how well they are flowing.
thanks.
Old Mar 5, 2003 | 11:28 PM
Mahjik's Avatar
Mr. Links
http://www.rceng.com/service.htm
Old Mar 5, 2003 | 11:57 PM
eric e's Avatar
haven't had my FD long enough to see the injectors yet but have done a lot of cleaning of stuck injectors on bmw k bikes
BIG WARNING
i have no idea how this relates to RX7 injectors, but if you're feeling like a little bonding time with your squirters you could do something like this
to test them i use 12 volts applied to the 2 connectors on the injector body and make sure they click open and closed whenever power is applied/removed
a happy injector is a tappy injector
gummed up injectors don't click!
leaving a stuck injector soaking in kerosene overnight will often soften the gum so that clicking it again with 12volts will eventually clear the injectors
to clear them more, once they are clicking, i clamp them onto the end of a suspended 3foot length of clear garden hose, fill the hose with kero and connect up the injector to 12volts
3foot of kero should provide enough pressure to run a stream out of the held open injector, if it only drips then they are still partially blocked but will provide enough gas, when installed back in the engine, to start the bike and allow me to run some injector cleaner through them along with the regular gas
http://groups.msn.com/2wheelsgood/80...to&PhotoID=405
eric e
oh, and to correct flow you are supposed to have them squirt into a container for a set length of time and check to see how much they put out...
i've never had to do this, if i get anything out of them they will normally run the engine at idle and allow me to put some cleaner through them...if that doesn't do it then they need professional cleaning
Old Mar 6, 2003 | 12:18 AM
yodaddy's Avatar
thanks guys that's exactly what i was looking for.
Old Mar 6, 2003 | 12:26 AM
AnthonyNYC's Avatar
Stay tuned...
This is good info. I never thought about using kerosene.
BIG WARNING
eric e
bryancmatthews
Power FC Forum
14
Oct 5, 2015 08:49 PM
ZacMan
Sep 19, 2015 09:20 PM
SCinfidel
Sep 8, 2015 05:36 PM
ZaqAtaq
Sep 5, 2015 08:57 PM
