driveline noise revisited
Old Mar 3, 2003 | 10:34 AM
Shaft checked, is okay, new front and rear u-joints. new tires, rims not dented, new struts etc.. 1982 model, automatic, problem is when it gets to 3000 rpm or around 45 mph, a serious vibration and noise starts. it seems as if it is coming from behind and under the stereo. At higher speeds, it still makes noise, but not quite as loud. Shifting into neutral, there is still the noise. Any ideas?
Old Mar 3, 2003 | 01:30 PM
RotorMotorDriver's Avatar
Seven Is Coming
Flexplate problems?
~T.J.
Old Mar 3, 2003 | 02:57 PM
Where is then flexplate located, and how can I tell if it is messed up or not?
Old Mar 3, 2003 | 03:06 PM
Seven Is Coming
Its where the flywheel would be on a 5 speed car (on the back of the engine. In between the engine and transmission). I dont know how to tell if its ok or not. It was just a wild guess. I dont even know if they can go out.
~T.J.
Old Mar 3, 2003 | 04:21 PM
It *might* be your tranny mount, which is more or less under the stereo area. I had to replace mine to get through inspection -the rubber had delaminated from the bracket. Your manual should tell you exactly where it is. Check it out!
S
96fd3s
38
Apr 19, 2021 06:50 AM
gxl90rx7
Haltech Forum
Jun 30, 2017 11:30 PM
Linda_Lovelace
Sep 18, 2015 10:04 PM
