Sponsored by: CARiD
HELP! Throwout bearing/lightened fly...
Old Aug 18, 2001 | 03:33 PM
Hey!
Although I ordered my new rebuilt block WITHOUT a lightened flywheel, Hayes decided to give me one... yeh!!! The only problem is, it won't work with the stock throwout bering.... what is the correct size/part number that I need?
Thanks!
Old Aug 18, 2001 | 11:23 PM
Wargasm's Avatar
Weird Cat Man
Huh?
A flywheel is a flywheel isn't it? Why won't it work with your throwout bearing?
Regards,
Brian
87 TII
93 R1
Old Aug 19, 2001 | 12:45 PM
spanacheck7's Avatar
How will it not work?
Is there no endplay?
Old Aug 19, 2001 | 05:06 PM
Re: How will it not work?
The clutch doesn't disengage and the pedal won't pop back with much force. There seems to be play. This flywheel is just a lightened stock flywheel. CAN ANY ONE HELP ME? DOES ANY ONE KNOW WHAT I"M TALKING ABOUT? (do I know what I'm talking about?) hehe
PLEASE HELP ME! I NEED TO DRIVE MY CAR!
Old Aug 19, 2001 | 06:46 PM
Henrik's Avatar
Re: Re: How will it not work?
Lightened stock?? How did they balance it? (the stock flywheel has the counter balance built in so if you just spin it by itself; ie after machining, it won't be balanced). You don't want an unbalanced flywheel spinning at 7k next to your feet. Also, if it is a stocker, you shouldn't have any problems with the throwout bearing. Check the clutch hydraulics for air.
Henrik
87TII
sinclair7seven
11
Sep 11, 2015 10:15 AM
Bambam7
Dec 24, 2003 10:06 PM
Doug_T2
Jan 2, 2002 03:37 PM
