Microtech wide band and lt8
Old Feb 25, 2003 | 12:17 AM
90pgt's Avatar
Newbie
wide band and lt8
can you use a wide band o2 with the lt8,or can you have it setup to run a wide band o2
thanks
chris
Old Feb 25, 2003 | 12:30 AM
10sec rx7's Avatar
No, only the LT/X 12 can be set up to run wideband support
Dale
Old Feb 25, 2003 | 11:26 PM
90pgt's Avatar
Newbie
whats the diffrence from the 8 and the 12 ,can the 12 still work on a four cylinder if so what does it cost with the coils, in US
thanks
chris
Old Feb 26, 2003 | 05:43 AM
rxeng's Avatar
The LTX12 is the top of the line microtech.
It has 6 injector drivers & 6 coil drivers compared to 4 & 4 with the LTX8.
This is used for 20B engines & 6 cylinders such as the 2JZ toyota & RB nissans.
They come with wide band logging capabilities & that's about the only difference.
The 12 is also run on 13B turbo engines with 2 primary,2 secondary & 2 auxilliary injectors.
Price ranges from around $1395 Aus ($825US) to around $1795 Aus ($1065 US) for one with coils,external map sensor etc.
Jon
Old Oct 30, 2003 | 07:04 PM
jreynish's Avatar
New Project on the Way...
currious will this be an option in the near futur for the lt-8? not that it really matter I am simply currious!
Logan Reinisch
44
Sep 17, 2018 12:20 PM
manoflego
19
Sep 30, 2015 05:19 AM
