stock se can last an 11000 rpm run....
Old Feb 23, 2003 | 08:41 PM
riffraff's Avatar
smog nazi destroyer
Exclamation stock se can last an 11000 rpm run....
i unfortunitally found this out.. i put my car on the dyno yesterday so that i could tune it.. my tach was not working (fixed it this morning) and so i was watching the monitor.. he hooked up the computer to the trailing coil, so i figured that it must be correct... we started, and it was taking a little while. about a minute later i was starting to wounder why it was taking so long to rev to 8k (but it sounded so good that i could not stop)... and then snap.. turns out that the comp was set to read at half, so when it said that i was at 5500 rpms, i was really at 11,000.
luckily it was the power steering belt. scared the **** out of me though.....car still runs fine, but has a bit of an oil leak now.... i am just glad that the internals in this motor are stronger than the ones in my 78 rx4 motor.
on the up side.. the car makes 156 to the wheels. stock internals, n/a.... respectable.
Old Feb 23, 2003 | 08:57 PM
onepointone's Avatar
i say what i want
HOW IN THE HELL DID YOU NOT NOTICE???? there a HUGE difference between 5500rpms and 11000 rpms.. even 3000 and 6000.. sorry dude, but thats fucked up that you didnt notice your car was sitting that high.
Old Feb 23, 2003 | 09:01 PM
JIMMY54's Avatar
GSL-SE PRO
11k? Wow! Glad to hear the engine lasted! Post the graph up. What mods do you have?
Old Feb 23, 2003 | 09:03 PM
What mods are you running? Stockport?
Old Feb 23, 2003 | 09:10 PM
RacerX7fb's Avatar
paradox
156 HP at the wheels at 11,000 RPM????? and STOCK ... SE's make 135 at the crank @ 6500 RPM... THATS nuts
Old Feb 23, 2003 | 09:16 PM
thorin's Avatar
don know hy, bnu this thread made me laugh. wich is good, becaus i am having the worst day of my life.
Old Feb 23, 2003 | 09:31 PM
1984special's Avatar
So little time and money
Exclamation Yikes
My bad double post
Old Feb 23, 2003 | 09:34 PM
Exclamation Yikes
Dude that's crazy. Post the dyno graph! I'm wondering how a 13B on stock internals spun up to 11k... That is truly evil! I have a '84 6-port 13B and it absolutely buzzes at redline (7k). You must be mad!
Oh yeah, the next time you go to a dyno you probably want to make sure you set up the tachometer right! I wouldn't want to pick up the pieces of that mess...
Old Feb 23, 2003 | 10:15 PM
Eville140's Avatar
If the dyno was reading the wrong RPM would the HP reading even be correct?
Just wondering
Randy
Old Feb 23, 2003 | 10:44 PM
MosesX605's Avatar
My wife bought me 2 RX-7s
The motor may seem fine now, but you may have sliced a large fraction of the operational life off this motor because of the mixup. I hope not, but 11k rpm is absolutely nuts on a stock motor.
Old Feb 23, 2003 | 11:07 PM
i say what i want
all i have to say is.. be glad your flywheel and clutch stayed in one peice.. otherwise.. you probably wouldnt be walking right now.
Old Feb 23, 2003 | 11:10 PM
NanaimoRx-7's Avatar
Ummm, you don't know the approx RPM of your car just by the sound? Lucky something (read flywheel) didn't come apart. Post a pic if you got it, I want to see this crazy graph. Hope she keeps purring for many miles.
Old Feb 23, 2003 | 11:58 PM
nimrodTT's Avatar
all aboard!
The flywheel/clutch in a 1st gen actually sits in front of the firewall, not too much danger of getting your feet cut off.
Stock stationary gears? I'd pull those out and throw them away if I were you.
Old Feb 24, 2003 | 08:16 AM
Sterling's Avatar
Nikki-Modder Rex-Rodder
You said "oil leak". From where?
Old Feb 24, 2003 | 09:54 AM
riffraff's Avatar
smog nazi destroyer
i just put a new exhaust on, so i donot have the sound down yet.. i was luckey.. like i said, i was just enjoying the sound tooooo much... mmm. it did sound beautiful in that garauge. i even had four or five people wander in to watch me dyno and tune it.
car didnot make power to 11,000, just reved that high.. i will post the graph if i can find a scanner...
it is a stock port se motor, racing beat dual exhaust, mikuni intake with custom cai and heat shelding, two msd 6a's and 3 blaster 2 coils. flywheel is a 9 pound flywheel (yup .. that is right.. 9 pounds.), and the cluth/pressure plate are centerforce. i am lucky that they lasted.
i fixed the oil leak comming from the oil temp/pressure sender (on the oil pedistal) but still have one that looks like it is comming form the oil pan seal. going to check that out tomorrow.
i pulled something like 152 on that run. pulled 156.8 a few runs later (i was tuning my carb).
i am not that worried about the longetivity of this motor. just need it to last a nother six months or so... hopefully i will have a new motor then (either turbo or n/a bridge. not sure which yet).
i cannot wait to get it onto the track (they would not let me run this weekend due to the oil leak). that power with the 5.12 rear end gears should make for a nice run. and @ 2300 lbs, it should definatly be respectable.
Old Feb 24, 2003 | 10:40 AM
Eville140's Avatar
I'll take the first guess
13.60's at around 98-100mph
Later
and good luck
Randy
Old Feb 24, 2003 | 12:06 PM
jeremy's Avatar
male stripper
typically the higher rpms will start to "chatter" the apex seals, leaving chatter marks on the housings and eventually snapping an apex seal. haven't heard as much about the side seals being as affected. you must have that special edition motor that takumi's father put in the hochi roku.
Old Feb 24, 2003 | 01:35 PM
fatboy7's Avatar
Got Boost?
I always thought you'd get rotor-to-side housing contact if you rev'd it much past 10k without clearancing your rotors..... your a lucky man, not to have roached you motor !
Queppa
Nov 18, 2024 03:47 AM
C. Ludwig
Jan 30, 2019 06:31 AM
msilvia
28
Apr 14, 2016 12:58 PM
CaptainKRM
14
Aug 26, 2015 09:52 PM
Microtech
Aug 23, 2015 11:04 AM
