Which aftermarket Clutch?
Old Feb 18, 2003 | 07:35 PM
Ojek's Avatar
Which aftermarket clutch do you guys use other than ACT?
Old Feb 18, 2003 | 10:07 PM
silverrotor's Avatar
What are your specs? If I never got a ACT, I would have gone with Bully Clutch? Found here www.bullyclutch.com Although, I am quite happy with my setup.
Old Feb 19, 2003 | 05:46 PM
killa7lb's Avatar
clutchnet....works good for me and i know guys who are making over 500hp and it works good for them
Old Feb 20, 2003 | 08:45 AM
exedy clutches
-signal the stage of street-
Old Feb 20, 2003 | 06:46 PM
vosko's Avatar
Just Call Me Terminator!
i have a special ACT full race setup it was $800 but it should be worth the $$$
Old Feb 21, 2003 | 10:34 PM
tcb100's Avatar
DinoDude
I don't make Vosko's power but my Centerforce has held up pretty well so far.
Old Feb 21, 2003 | 11:19 PM
West TX RX-7's Avatar
Da Monee Pit
The best for the money deal right now.
it's ACT but ACT is good..
http://66.216.67.51/subcatmfgprod.asp?0=206&1=290&2=-1
Old Feb 22, 2003 | 11:56 AM
Whats your opinion of OS Giken twin plate?
Old Feb 23, 2003 | 11:55 AM
Jesuscookies's Avatar
I can haz rotary?
Doe's anybody have experience with this style clutch at the link below?
http://www.rotorworx.com.au/perfor_clutch.html
The one I am referring to, is at the very bottom of the page.
Old Feb 23, 2003 | 11:58 AM
82streetracer's Avatar
8/1 Building/Drive Ratio
multiple plate clutches create holding power with more discs rather than raw clamping pressure.
you get huge holding power and smooth engagement.
but you get a 1500-2000 price tag.
Old Feb 23, 2003 | 07:44 PM
I can haz rotary?
Okay,
will they hold up to 500RWHP abuse?
is this a better option then an ACT performance clutch for street use?
Or can an ACT clutch do pretty much the same thing for less?
Old Mar 14, 2003 | 11:04 PM
Node's Avatar
they use 4 plate ATS carbon/carbon clutchs on indy cars well some older ones, or was it f1? i forget
and a lot of big hp skylines use them too
ont ATS carbon/carbon clutchs, but normal multi plate clutchs. Theres a difference between that carbon/carbon and other materials, im not exactly sure, but here carbon//carbon is more expensive but better
Old Mar 14, 2003 | 11:22 PM
ZoomZoom's Avatar
SEMI-PRO
I have a 6 puck stage 3 Kevlar and Ceramic unsprung ACT disc with the HD ACT pressure plate. With 440rwhp. The first week was very grabby and now I have learned to drive it just like the Street/Strip sprung clutch. I am sure it will hold up for you. I also plan to turn up the boost more and get up near 500hp. I have no worries about my clutch. You can always get a higher end unit. Vosko has some kind of Special ACT Clutch. Its not available on thier list of clutches but can be made by request.
sinclair7seven
11
Sep 11, 2015 10:15 AM
REX7&Z32TT
Sep 9, 2015 05:16 AM
Enzo1944
Sep 6, 2015 08:57 AM
