question on greddy elbow install!!help
Old Feb 7, 2003 | 10:46 PM
Hey guys wuz up,jst bought the greddy elbow w\o bov flange ,but as Iwas looking at how to attack this I noticed that the greddy doesnt have that hose connector on the back side ???What is that hose and what do I do with it .Or did they send an incorrect elbow ?It appears to either act as a pcv valve or a vacuum line ?it almost touches the firewall.Hey thanks for the time !
Old Feb 7, 2003 | 11:08 PM
RX7FAN's Avatar
It's correct
You have the right one unless you wanted one with injector ports...
You can have a tube welded in that place to reconnect your hose or you can block off that hose. if you have a power FC I do not think it is used anyway...
Old Feb 7, 2003 | 11:09 PM
duboisr's Avatar
That is the fast warm up system that makes it rev up to 3000 rpm cold (not good, not needed ) just remove the parts not needed and leave the electric parts for the ECU to use . you can just block off the hose to the elbo if you do not want to make blocking plates .
Old Feb 7, 2003 | 11:13 PM
apneablue's Avatar
Hey See this thread
should help
rotor_veux
46
Jun 12, 2018 10:39 AM
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
