Haltech I still cant get may tach working on my t2 w/E6K!
Old Feb 2, 2003 | 12:56 PM
pistonsuk's Avatar
is there any way to use the tacho output and wire it directly to the factory tach? does anyone have a factory tach in there 2nd gen w/e6k?
please help
justin
Old Feb 4, 2003 | 03:12 PM
Factory tach should work fine as long as you didnt' cut all the wires that go to the trailing coils.
Also as long as you have the trigger wire correct and the software settup correctly.
Old Feb 4, 2003 | 09:12 PM
pistonsuk's Avatar
tach
someone told me to hook up the leading coil wires. do these need to be hooked up too? i will tap the factory trailing harness back into the tailing coils.
thanks
justin
Old Feb 6, 2003 | 01:45 PM
pistonsuk's Avatar
Tach?
i now have all the original wires hooked up from both leading and trainling coils. still no tach. must i retain the factory ecu? is there a way to just hard wire the factory tach to the tacho output?
thanks
justin
Old Feb 6, 2003 | 07:09 PM
kabooski's Avatar
Laying Down Rotary Law
did you cut the yellow wire?
Old Feb 11, 2003 | 01:07 PM
pistonsuk's Avatar
dont think so
i have all the factory igniter wires run to the ignitors. i Dont have the factory ecu in, is this a problem? i lloked up the wireing schematic and the tach input is the yel wire and it shows it coming from the trailing coil. ??? should i cut this wire and run it to a tacho out put of the e6k?
thanks
justin
Old Feb 13, 2003 | 12:34 AM
pistonsuk's Avatar
this might be it
i cut all the unnessassary wires on the main engine harness. all except the coolant wires. i think the resisor pack some how was completeing this circuit. do you think this could be the problem? i'll check into it
justin
Old Feb 14, 2003 | 05:42 PM
pistonsuk's Avatar
ok it works!
i ended up cutting the yellow wire with blue stripe right behind the tach and hooking it directly to the factory tacho output on the leading coil. this is a short wire with a female bullet connector.
justin
streetlegal?
Mar 17, 2022 02:46 PM
Thor 18
Interior / Exterior / Audio
Sep 13, 2015 08:39 PM
freq
Microtech
Aug 23, 2015 11:02 AM
freq
Aug 21, 2015 03:30 PM
