Who still has the metal underpan?
Old Jan 27, 2003 | 01:58 PM
GLHS's Avatar
Shelby Tuner & FC badass
Who still has this on thier cars?
Does anyone know the purpose of it? It doesn't appear to have anything to do with airflow.
Can anyone shead some light on this one part?
Old Jan 27, 2003 | 02:36 PM
jeremy's Avatar
male stripper
check the other thread.
Old Jan 27, 2003 | 02:39 PM
darkwaveboi's Avatar
Need donor car in Fairfax
my underbody panel is plastic...it helps direct the airflow through the radiator.
Old Jan 27, 2003 | 02:40 PM
Samps's Avatar
Mine's plastic (91 vert) it helps keep the engine bay clean and dry also.
Old Jan 27, 2003 | 02:43 PM
1FastT2's Avatar
Ah, im not sure any of the underpans where made of steel.
Old Jan 27, 2003 | 02:48 PM
CrackHeadMel's Avatar
Learned alot | Alot to go
if i recall i had a metal underpan behind the plastic one that was below the engine
Old Jan 27, 2003 | 02:58 PM
KiyoKix's Avatar
13B N/A POWA!
Do you have one of the sport aero kits on your car (or at least the front part of it)? That metal underpan that you speak of is part of that kit to further enhance the effect of the aero kit. The full kit was the "side skirt" attatchments, the front bumper attatchments, the rear spoiler, and the front underpan (that you're talking about). If not, maybe someone put it on there anyway. Either way it's not a bad thing (very good actually) ...consider yourself blessed.
Old Jan 27, 2003 | 03:00 PM
KiyoKix's Avatar
13B N/A POWA!
In case you were wondering, the metal underpan wasn't in place of the plastic one, it was after it to complement it...so yes crackhead (haha) that's what he's talking about.
Old Jan 27, 2003 | 03:10 PM
Rotorific's Avatar
I dont know a damn thing
It goes after the plastic underpan and there is a specific cutout for the oil drain plug. ROYJAMES has one and is not letting go of it. heh. -Gabe
Old Jan 27, 2003 | 03:16 PM
Aaron Cake's Avatar
Engine, Not Motor
There are two underpans, the plastic one and a metal (aluminium as I recall) one that goes under the oil pan.
The plastic one is absolutely required for proper cooling.
The metal one is part of the aero kit (as already mentioned) and is not really required, but is nice to have.
Old Jan 27, 2003 | 04:17 PM
silverrotor's Avatar
Here we go again Aaron.
Old Jan 27, 2003 | 08:19 PM
White_FC's Avatar
Just so you know, my car cools fine without it.
Old Jan 27, 2003 | 08:26 PM
Manolis_D's Avatar
Ditto here!
Old Jan 27, 2003 | 08:28 PM
KiyoKix's Avatar
13B N/A POWA!
What do you consider "fine"?
Old Jan 27, 2003 | 08:44 PM
Manolis_D's Avatar
189* at almost all times, verified through a haltech
Old Jan 27, 2003 | 10:11 PM
White_FC's Avatar
1/4 on stock temp gauge cruising around town, 1/2 on gauge when i'm circuit racing/going for a strap down the highway.
*Ambient temp=~30-32 deg. C, Humidity=~100%
Edit: Incidently these are the same temps I had (if not cooler) than when I had this thing on.
Old Jan 27, 2003 | 11:52 PM
NZConvertible's Avatar
I'm a boost creep...
Well I wouldn't consider that fine. It's not supposed to get that high even if the engine's under load.
It's not hard to understand that without the undertray a lot less air will go through the radiator and oil cooler. Air always follows the path of least resistance, and without the undertray, that's under the coolers, not through them.
Old Jan 27, 2003 | 11:57 PM
MasteRX's Avatar
More Than Meets the Eye
Dont forget that the main tray also directs air to the oil cooler. Even if your water isnt running hot, your oil might be.
Old Jan 28, 2003 | 12:49 AM
White_FC's Avatar
You think half way on the gauge is too hot? oh well, time to get my self some real gauges and see what the temp really is I guess..
Old Jan 28, 2003 | 06:36 AM
GLHS's Avatar
So the metal one is the aero kit... I see. Can anyone get silly with this and explain, what its doing? just directing air, is that all?
I thought it would be for AWD driving...skid plate..J/K
Old Jan 28, 2003 | 06:58 AM
vicious525E's Avatar
ya, mine too, but mines probably partly due to the HUGE e fan i got
Old Jan 28, 2003 | 09:06 AM
KiyoKix's Avatar
13B N/A POWA!
Well then...I would not say that 1/2 is fine, but hey nothing is wrong if you don't know it right . I'd go ahead and get the other gauge just in case...undue stress on the cooling system might not hurt you while driving, but will shorten it's lifespan.
Anyway...onto the metal "skid plate" all it really does is help to streamline the underside of the car further than the plastic one does. If there is a smoother area obviously there's less turbulence and better aero efficiency. That's the short version of it, hope that helps.
Old Jan 28, 2003 | 10:16 AM
Mr. Eccentric's Avatar
Who owns the Chiefs?
Anybody remember what happened last time this topic was posted?
Old Jan 28, 2003 | 11:47 AM
KiyoKix's Avatar
13B N/A POWA!
Nope...care to elaborate???
jdmbrendan
Oct 1, 2015 01:29 AM
Duc852
Sep 22, 2015 03:49 AM
lordderak
Sep 19, 2015 12:14 PM
