Can I shove a TII radiator in my 83?
Old Jan 26, 2003 | 08:13 PM
Mschafe's Avatar
Where did my 7 go?
I have access to a great condition TII radiator. I was wondering if this would bolt in, + I was wondering if I could use a TII Air-Oil cooler with this radiator.
Matt
Old Jan 26, 2003 | 08:39 PM
MIKE-P-28's Avatar
Driven a turbo FB lately?
with some fabbing I dont see why not, you will have to ditch all the radiator support stuff you currently have, you are own your own for brackets and for the brackets for the condenser
Old Jan 26, 2003 | 08:42 PM
setzep's Avatar
Mike is right on this one. It can work but you'll have to make new brackets for it all. Why do you want to change radiators?
Old Jan 26, 2003 | 08:44 PM
MIKE-P-28's Avatar
yeah and the t2 rads from 2nd gens have plastic tops and bottoms, they suck ask me how i know
Old Jan 26, 2003 | 08:49 PM
MIKE-P-28's Avatar
What do you mean right on this one? Im right everytime, man I thought I taught you better than that LOL
Old Jan 26, 2003 | 08:52 PM
setzep's Avatar
I was simply pointing out that you were actually right for a change, thats all
Old Jan 26, 2003 | 08:55 PM
MIKE-P-28's Avatar
**** im right everytime
Old Jan 26, 2003 | 08:57 PM
setzep's Avatar
Ahem! You taught me??
Old Jan 26, 2003 | 09:12 PM
MIKE-P-28's Avatar
well there was a few things, i was uhhhm curious about LOL
Old Jan 26, 2003 | 11:08 PM
Felix Wankel's Avatar
Super Newbie
If its am 88 model, it probably has a filler cap on it, sp you'll have to angle it. If its any other year, it won't have a a filler cap, and you'll have to change thermostat housings. With eithe rone you'll have to modify the TII upper radiator hose, the FB one probably won't fit. Too much damn work for a downgrade if you ask me.
Old Jan 26, 2003 | 11:15 PM
Manntis's Avatar
add to cart
...I thought I was wrong once, but I was mistaken...
Old Jan 27, 2003 | 12:13 AM
rotary emotions's Avatar
HEAVY METAL THUNDER
Ok guys, all nice and easy... but get to this question then: if a TII rad isn't worth the work, then what rad do you recommend??? Let's say you have a engine conversion and "drop in" a 13B TII or, why not a RE or REW. You are going to need some cool water, yes? So, tell me: what'd be the best choice then?
I was thinking, if you can squeeze in a FC rad, you can squeeze in a aftermarket one for a FC too...
So those of you with monster turbo power: what rad are you using???
Old Jan 27, 2003 | 12:18 AM
RotorMotorDriver's Avatar
Seven Is Coming
My step Mom says that all the time...The weird part is shes basically never wrong.
~T.J.
Old Jan 27, 2003 | 12:20 AM
Directfreak's Avatar
I am a Jeeper Now.
Stock.
BTW, If you're gonna Turbo in the future...
I recommend the short Three-row used in the 79-82's with the bottom mounted oil cooler.
Leaves you with less headaches later for a FMIC.
Old Jan 27, 2003 | 12:26 AM
HEAVY METAL THUNDER
Originally posted by Directfreak
Stock.
Hmm, that's just what's in there right now...
And indeed, I'm going turbo in the very near future. Planning a FD engine conversion. I know it has been done, so if anyone knows a link about this. Of course a link to a 13B Cosmo swap would also be very good.
Before anybody says I'm crazy: yes, I know I am. And yes, it should fit my budget. And no, it is not really legal overhere
Old Jan 27, 2003 | 12:50 AM
I am a Jeeper Now.
The Sticky Turbo TII into GSL-SE thread on top will be your friend.
Old Jan 27, 2003 | 12:56 AM
HEAVY METAL THUNDER
Familiar with that one... Just wondering about FD engine specific problems. Like the sequential turbos and stuff like that.
Old Jan 27, 2003 | 01:30 AM
I am a Jeeper Now.
Ohh..Good luck. Maybe running them Non-Seq, but true Seq? EEEK. It looks like Medusa's head down there with all the vacuum lines, etc.
I'd recommend a "regular" TII anyday over an FD swap.
Old Jan 27, 2003 | 01:54 AM
HEAVY METAL THUNDER
Yes, but then again, that'd make me a regular, yes? :-)
So, I'm going the FD route... I'll try to start out with the FD engine as a long block, using as many FD parts as possible. However, I will delete most emission controls, as I won't need them to pass smog test in Belgium. At least not in a SA/FB. So that'll save some vac. lines.
Still wondering about the gearbox...
Old Jan 27, 2003 | 06:54 AM
S2-13BT's Avatar
Yup as DF mentioned, the stock SA rad and oil cooler is the way to go. Of course an aftermarket SA rad would be better, but the stock unit will work fine.
As for the FD engine we were just discussing it on ausrotary.com and believe that it will fit, with the stock turbos. Not sure about the FD tranny, I'm sure it'll fit but how? It also seems popular to run the twins non seq to save problems with the vac lines ( they cause probs a lot it seems).
Good luck with it though.
Old Jan 27, 2003 | 03:40 PM
GatorRX's Avatar
Stock early-style 3 row and stock air/oil cooler were plenty to keep my old half-bridgeport cool and happy in town with the A/C running in the summer, should be more than enough for for a turbo motor.....
Old Jan 27, 2003 | 05:24 PM
setzep's Avatar
Directfreak is right. Stock is all you need for a street car. Think about it, how long are you typically in the boost for??? About 10-15 max at a time. Because by the time 15 seconds go by you're doing 150mph So you're not making all that power all the time, just when you are boosting. Boost=power=heat. Otherwise a turbo rotary isn't much different than a n/a. Look under the hood of AJC-13B, you will find a stock radiator and he has close to 600BHP
Old Jan 28, 2003 | 02:24 AM
HEAVY METAL THUNDER
hmm, ok, seems a good answer :-) Well, actually I hijacked this thread a bit... sorry...
JoesFC
Oct 5, 2015 08:10 AM
FC_DREAMS
Sep 9, 2015 06:24 PM
