Non-seq boost control setup
Old Jan 26, 2003 | 12:13 PM
Jedon's Avatar
Slave2TheFD
Please help me, and verify that this is the correct way to hook up a profec when you are non sequential.
Thanx!!
What do I set the needle valve to, halfway open? mostly closed? mostly open?
Old Jan 26, 2003 | 01:18 PM
cewrx7r1's Avatar
Eye In The Sky
Needle valve is not needed. You cap off the that nipple that originally went to the WG solenoid.
Old Jan 26, 2003 | 01:22 PM
Jedon's Avatar
Slave2TheFD
Thanx!
Right now I have the needle valve in between the turbo and wastgate and the other side of the wastegate capped off but I can't get more than 9psi :-(
Skeese
65
Mar 28, 2017 03:30 PM
