sideways on accel/decel
Old Jan 24, 2003 | 01:43 AM
i've always noticed that when weight is transfered to the rear of my fd, the nose pulls left, weight to front nose pulls right. never thought much of it until it got real cold the last few days and it became much more pronounced. the pull is visible when looking over the hood of the car, and has a very unsettling effect on the car when accelerating/deccellerating in a turn. what causes this and how can i stop it? oh, car is stock with recent rebuild and 130k on chassis. don't believe the shocks have ever been replaced.
Old Jan 24, 2003 | 02:47 AM
Kahren's Avatar
i am not a girl
alignment would do that uneven tire wear as well
Old Jan 24, 2003 | 03:11 AM
BrianK's Avatar
replace the shocks for frick's sake - that's more than likely the culprit. Torque is what does it (I assume that when you decel it's while it's still in gear) - that's why you see drag cars lift one wheel off the ground when the accelerate hard... the engine is trying to turn the car over.
Old Jan 24, 2003 | 03:13 AM
maxcooper's Avatar
WWFSMD
First step: check your tire pressures.
-Max
Old Jan 24, 2003 | 09:31 AM
if it were tire or alignment problems, would it not pull one way all the time? with the wheel in the same position, the difference between accelerating and decelleration produces a noticeable change in the direction the car travels. its as if i turned the wheel an inch in that direction.
Old Jan 24, 2003 | 11:37 AM
es's Avatar
es
Listen to Max & check your tire pressure. If the pressure is ok then you could have lots of slop in the bushings changing the rear toe angle under accel/decel making the car basically crab...
Old Jan 24, 2003 | 01:44 PM
Kahren's Avatar
i am not a girl
when u acclerate the rear adds some to where the car is going when u brake its mostly your front end thats steering. unless your brakes are lockign up diffrently.
Old Jan 24, 2003 | 03:46 PM
adam c's Avatar
Cheap Bastard
When you brake, the front end comes down, creating a specific wheel alignment. When you accelerate, the front end comes up creating a different situation. Either way, the car should go straight. Tire pressure is easy enough to check. Start there. That probably won't fix your problem. An inspection by a competent alignment mechanic should tell you if there are worn parts, or a bad alignment, or both.
The shocks can't be any good with that many miles.
Adam
Old Jan 24, 2003 | 07:05 PM
FDjunkie's Avatar
Go with Max. I discovered a (fortunately) slow leak in one of my back tires because when it lost enough air pressure, the tire's rolling radius shortened and this created unequal torque. On even light acceleration / de-acceleration the car wanted to turn back and forth exactly as described by tulin.
Old Jan 24, 2003 | 10:39 PM
thanks for all the info guys. i will check the tires in the morning and go from there.
Old Jan 25, 2003 | 12:35 AM
Kahren's Avatar
i am not a girl
how can u drive your car and not remotely know what your tire pressure is, it shoudlbe at teh very least be cheked weekly!
Old Jan 25, 2003 | 06:56 AM
jeff48's Avatar
Rotorally Challenged
This is true----of course you can get obsessive about it---like me and install one of these----------->
http://www.tirerack.com/accessories/...artire_all.jsp
Barwick
128
Mar 21, 2005 07:28 PM
genII Drifter
Sep 22, 2003 05:01 PM
Manntis
52
Jul 2, 2003 12:15 PM
RotorMotorDriver
27
Feb 19, 2003 06:27 PM
Josepi
Dec 4, 2001 05:49 PM
