fd throttle body on a 20B?
Old Jan 23, 2003 | 11:48 PM
RX-Heven's Avatar
I'll blow it up real good
I swear I just read someone was doing this due to larger secondaries or something on the fd tb. I can't remeber where or I saw or read it , or even if I did for that matter. Am I high? Just need to have this settled.
thx
Old Jan 24, 2003 | 07:00 AM
94RHDFD's Avatar
Formally 20b 3rd gen
Your are not mistaken, I am using my 13b TB w/ a 4mm bore
Old Jan 24, 2003 | 12:12 PM
j9fd3s's Avatar
Community Builder
the bolt patterns are the same, the bac passage is slightly different, and needs to be blocked or something.
mike
Old Jan 24, 2003 | 09:26 PM
RX-Heven's Avatar
Is that a 13bt or 13brew tb, and would you two care to elaborate more on the details/differnences.
thx again
Old Jan 25, 2003 | 05:31 PM
Turbo 3's Avatar
Safety Guy
I thought the FD TB didn't have the front set of butterfly plates like the FC and cosmo motors?
I just stuck with the 20B TB and did the TB mod to it.
Old Jan 28, 2003 | 07:18 PM
DMRH's Avatar
20B one is larger. (slightly)
Looked both just a moment ago to compare.....
Old Jan 28, 2003 | 07:41 PM
RETed's Avatar
20B primary bore is slightly larger, but the primary throttle plate is identical in dimesions as the FD 13B-REW primary throttle plate.
I measured with a caliper myself.
-Ted
Old Jan 28, 2003 | 08:28 PM
RX-Heven's Avatar
So are the secondaries larger also. I would assume so, but I do not have a 13brew tb to compare with.
Old Jan 29, 2003 | 07:35 AM
PaulC's Avatar
Three spinning triangles
From: Been all around this world and still call Texas home (Ft Worth)
Yet another bit to add to my list for my conversion.
The list is growning faster than I'm getting parts for it
