Stuck Floats can cause fires!
Old Jan 15, 2003 | 02:26 PM
Randy Nix's Avatar
Yesterday afternoon when I got home I noticed that as I turned in my driveway my rex ('83 GSL) acted like the floats were stuck open. It's done this twice before and I hit the carb to loosen the valves and it fixed it. So I thought fine, I'll take the beer in the house and check the carb before I go into town to get food and more beer. After sitting for 10 minutes enjoying my beer my wife said that she saw smoke outside. I opened the front door and could not even see my car through the thick black smoke. My car was on fire! I tried to pop the hood to put it out and broke the hood release cable! My wife got me water that I poured through the crack at the back edge of the hood. I got it out after four pans of water. Now the hood, which was pretty black before, has the paint burnt off in a two foot circle. The rat's nest I was planning on removing soon is history. The fire was centered around it! Wires to alternator burnt, clutch slave cylinder rubber line gone, both gas lines gone, new air filter and distributor cap gone, spark plug wires destroyed. Oh well, it could have been worse! The moral is to fix your car when gas can leak onto hot parts, fires do happen.
Old Jan 15, 2003 | 02:40 PM
riffraff's Avatar
smog nazi destroyer
Old Jan 15, 2003 | 02:50 PM
79+80_rx-7's Avatar
pics of the heart break?
sorry to hear man!
Old Jan 15, 2003 | 02:52 PM
Randy Nix's Avatar
I don't have a digital camera, wish I did. The picture would be awsome, the rat's nest is not even recognizable, just a burnt mass of plastic.
Old Jan 15, 2003 | 02:53 PM
rx7_freek's Avatar
Code and Rotary Hacker
Ouch...THAT has to suck! I bet you were
Old Jan 15, 2003 | 03:15 PM
riffraff's Avatar
smog nazi destroyer
how much is salvageable
Old Jan 15, 2003 | 03:27 PM
Randy Nix's Avatar
I figure I can fix it for $40-50, not counting painting the hood or carb kit. I'm lucky, it only burned the plastic and rubber on the top of the motor around the rat's nest. If that's not a clear indication to remove the nest I don't know what is!
Old Jan 15, 2003 | 04:00 PM
pillage6's Avatar
FUEGO!!
Old Jan 15, 2003 | 04:19 PM
faye x7's Avatar
brilliantly stupid
hahaha...i think I'd **** myself if I saw my car on fire......
Old Jan 15, 2003 | 05:49 PM
85RX7GS's Avatar
Re: Stuck Floats can cause fires!
That stinks man! At least this disaster saved you the trouble of removing the "rats nest"
Old Jan 15, 2003 | 06:38 PM
Rx7carl's Avatar
Airflow is my life
Double post sry.
Rx7carl's Avatar
Airflow is my life
So you left it running while you had your frosty? Or was it shut off? Oh sorry to hear about the fire, but yes it could have been ALOT worse.
Old Jan 16, 2003 | 07:44 AM
drippa's Avatar
i didn't do it
that sucks man i think my carb is leakin a lil fuel too i guess i'll have to take a look
Old Jan 16, 2003 | 08:36 AM
Randy Nix's Avatar
It was turned off, but hot after a 25 mile run home. At least I didn't short out the electrical system since it was turned off! I'm going to get a picture of it before I fix it. I'm sure everyone will get a kick out of my burned rat's nest.
Old Jan 16, 2003 | 08:40 AM
djmickyg's Avatar
sounds like something from a nightmare. sorry to hear that, hope it dont cost tooo much to get it running agian..
ls1swap
Jun 3, 2024 03:25 PM
LongDuck
Oct 7, 2015 08:12 PM
subeone
Sep 24, 2015 09:58 PM
