Haltech FD coolant level beep and light
Old Jan 11, 2003 | 07:43 AM
streetpower's Avatar
How do i turn the warning lite off and beep off....i have e6k flying lead and removed engine harness
Old Jan 11, 2003 | 01:11 PM
rxrotary2_7's Avatar
i dont know if this is the best way. but i think i shaved off the insulation around (i think it was) a brown wire (not to sure about the color, look it up in the wiring manual) up in one of the 2 grey conectors (driver side) near the battery, and grounded it.
the coolant acts as a ground and since i did away with the sensor, this was an easy fix for the buzzer.
Old Jan 14, 2003 | 08:09 AM
Would it be the brown and white wire...i did not work....any other hints
Old Jan 14, 2003 | 11:20 PM
you can pick the signal up there. not so sure of the color, but i remember it being brown on mine. i will double check in the morning.
Old Jan 22, 2003 | 03:32 PM
Styk33's Avatar
Haltech E6K
Arrow
To keep it from beep you need to ground the wire that goes to the coolant level sensor. If you removed the sensor just follow it back to where you cut it.
rx7shirley
Sep 2, 2015 02:11 PM
