Tires, tires, and more tires! Grrrrrr. :(
Old Jan 8, 2003 | 11:16 PM
error402's Avatar
#!/sup_mod/üb3rg33k
Unhappy Tires, tires, and more tires! Grrrrrr. :(
I am going nuts here looking at tons of tires. I'm currently looking at these...
Yokohama AVS ES100 - Size 205/60HR14
http://www.tirerack.com/tires/tires....num=06HR4ES100
What would you guys get for 14" wheels?
-Error402
Old Jan 8, 2003 | 11:34 PM
RacerX7fb's Avatar
paradox
Not much of a good selection for 14's but those Yoko's look good. Performance in rain is important to me. For dry and autoX, I will have some Falken Azennis on my stock SE wheels. check em out here : http://www.falkentire.com/html/
Old Jan 8, 2003 | 11:44 PM
error402's Avatar
#!/sup_mod/üb3rg33k
RacerX7fb thanks for the suggestion.
I saw these I seem to like...
Falken 195/60R14
Race-Bred Ultra High Performance
...but I didn't see a price.
-Error402
Old Jan 8, 2003 | 11:52 PM
RacerX7fb's Avatar
paradox
Yes thats the Azennis.. I believe that they go for about $65 each, depending on where you purchase them. Tirerack should be able to get those for you plus shipping or your preferred tire dealer in town.
Try also http://www.toyo.com/ and http://www.nittotire.com/intro.htm
Old Jan 8, 2003 | 11:59 PM
Kill No Cone's Avatar
The Azeins stick like they are glue. Last year I bought Yoks and now, wish that I had the azenis. At the autocross also sorts of folks are using them and doing really well.
Old Jan 9, 2003 | 12:47 AM
error402's Avatar
#!/sup_mod/üb3rg33k
Yeah the Azeins look awesome for traction, but they look like they wouldn't be any good in the wet. I would prefer something that is driveable in the rain.
-Error402
Old Jan 9, 2003 | 02:35 AM
V8kilr's Avatar
Re: Tires, tires, and more tires! Grrrrrr. :(
-Error402
damn those look really nice.I want em just for show on my ranger
Old Jan 9, 2003 | 08:53 AM
error402's Avatar
#!/sup_mod/üb3rg33k
Any other comments or recommendations people?
-Error402
Old Jan 9, 2003 | 09:05 AM
David88vert's Avatar
r71's daddy
I use S-03's, but I think they are only available in 15" or bigger. Great for any condition though.
Old Jan 9, 2003 | 09:08 AM
pillage6's Avatar
My roommate has S-03s on his S2000, says they are great.
I have AVSs on my car and have had no problems, will try S-03s soon though.
Old Jan 9, 2003 | 09:27 AM
error402's Avatar
#!/sup_mod/üb3rg33k
Yeah...well, that doesn't help me when I am looking for tires for 14" wheels.
-Error402
Old Jan 9, 2003 | 10:25 AM
851stgen12a's Avatar
Off riding sportbikes!
BfGoodrich G-force Kd's or Kdw's. Not sure if they have them for the 14" but, I have the Kd's in a 205/50/15 and these things stick like freaking Glue!! awsome in the rain as well...
Old Jan 9, 2003 | 10:46 AM
Wankelguy's Avatar
My FSP Fiesta eats Jettas
14" wheels
A set of 14" wheels to fit the 4 on 110mm bolt pattern will take some searching on your part. The first ones that come to mind would be the '83 RX7 Limited Edition wheels, also called "snowflake" wheels, but there are other aftermarket wheels by Riken, Enkei, etc. which you may be able to find.
Here's a picture of the LE wheels.
Good luck! -WG
Old Jan 9, 2003 | 10:55 AM
error402's Avatar
#!/sup_mod/üb3rg33k
I already have the 14" wheels. I'm looking for what type of tries to mount on them. I have the Honey Comb wheels, they are my favorite.
What tire measurements are people using with 14" wheels?
-Error402
Old Jan 9, 2003 | 11:41 AM
JEC-31's Avatar
Plastic Jedi
I've got some 14x7 meshs too, how wide and low can we get on these?
Old Jan 9, 2003 | 11:48 AM
lotsacars's Avatar
Falken 195/60R14
-Error402
I replaced my factory issue Pirelli P6 205/60VR14s with Pirelli P8000 Vizzola (Sears/NTB only, now discontinued) 195/60VR14s and they are noticably narrower. I had my SE parked next to my folks' SE which has the 205s and there was clearly a difference in width. They have AVS Intermediates in the back and RE71s in the front - both also discontinued, but may give you a point of reference.
As far as performance, I'm relatively happy. Only 'relatively' because in AutoX'ing it this summer I experienced quite a bit of oversteer. I can't help but wonder how much of that would be eliminated with a 205 and a lower treadwear rating. They do however work flat out AWESOME in the rain; they have a big ol' channel running down the middle of them.
When it comes time for new tires I'll likely step up to 15s or 16s as tire selection just doesn't exist anymore for 14s. That and I'm going back to 205s or better. HTH.
Old Jan 9, 2003 | 02:51 PM
rotor-lynn's Avatar
I switched over to 14" SE wheels this summer and put Bridgestone Potenza RE950 195/60HR14's on them. I don't autox but they've seen close to 100mph at Portland International Raceway and stuck like glue in the turns. They also work great in the rain.
Old Jan 9, 2003 | 03:02 PM
Narcisse91's Avatar
www.discounttiredirect.com for the Azenis. Last I checked, TireRack didn't carry them. Great for autocross, but I've heard they're not too good in wet weather.
Old Jan 9, 2003 | 03:09 PM
357's Avatar
357
Stratoflattener
Yeah, the Azenis goes for 50 a tire in the size you're looking for at www.discounttiredirect.com. My friend uses them on his Subaru Impreza 2.5RS for street and autocross, and he really likes them, even more so cause they're cheap.
Old Jan 9, 2003 | 03:41 PM
error402's Avatar
#!/sup_mod/üb3rg33k
$50!!! Woo hoo!
-Error402
Old Jan 9, 2003 | 04:49 PM
357's Avatar
357
Stratoflattener
Conversely, if you wanted an even cheaper tire, you could get 185/60VR14 Yokohama AVS Intermediates from the Tire Rack (www.tirerack.com). Haven't known anybody with them, but they're basically a road version of an open-wheel rain tire, so I can't imagine they'd be too bad, especially at $41 a tire, and with a 160 A A UTQG rating, compared to the Azenis' 200 A A rating. Also, it's probably going to be easier to find a place to do Yoko warranty stuff, if you need it. Just a thought.
Old Jan 9, 2003 | 05:10 PM
rx7 Nut's Avatar
I would have to put a vote in for the Azenis. I put them on my SE in the middle of last summer and do they every stick. Unless the rain was really heavy i found them to be alright in the wet surprisingly. The only drawback I can think of is the 200 wear rating. Mine are half worn already. But thats what you get for buying soft tires i guess.
Old Jan 9, 2003 | 07:12 PM
zookeeper's Avatar
Retro Rocket
Dunno, guess I'm just old fashioned...
P215/60R14
Good chuck of meat on the ground that seems to be glued to the pavement. Good wet traction, too.
Old Jan 9, 2003 | 08:13 PM
suntzumd's Avatar
I put some Summitomo HTR 200s on my SE a few months back. $42 bucks at tire rack. Grip good but have some side wall flex that can take a little getting used to if you jerk the wheel. Pleasant bang for the buck.
Old Jan 9, 2003 | 08:55 PM
coldy13's Avatar
Yeah, shutup kid.
I love my set of yoko es100's, 195-50-15. I used them all last summer, GREAT traction in wet and dry, extremely quiet, great tire for the street. I don't know how well they do at auto-x, but I'll be finding out this coming summer. If there's any snow durring winter where you live, keep an extra set of winter tires on some cheap stock rims, es100's DO NOT give ANY grip if there is snow coating the road.
