Sponsored by: CARiD
question for rotary gurus
Old Jan 5, 2003 | 10:06 PM
eddierotary's Avatar
back with rotaries
what is the diference in the 12a's front rotor and the rear rotor? is theres a diference. thanks
Old Jan 5, 2003 | 10:18 PM
Project84's Avatar
Open up! Search Warrant!
I want to say that the bathtub shape is different on the top then on the bottom. If you were to put the front rotor in the rear housing, then you would have to turn it to face the opposite direction to get the gears onto the stationary gear. This will now cause the front rotor to be rotating opposite the direction it would if it were in the front since you turned it 180 degrees. The shape of the bathtub would be approaching the compression side of the housing backwards from what the engineers intended.
Confused yet?
travenport
Aug 29, 2015 11:15 AM
turbo-minivan
Aug 27, 2015 07:56 AM
elfking
Aug 19, 2015 09:48 PM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
