87 GXL BRAKE problem
Old Jan 2, 2003 | 06:17 PM
Question 87 GXL BRAKE problem
I have had trouble with my brakes for sometime now. I have been loosing a lot of fluid from my resivour and now my brake pedal applies nearly no pressure to stop the car. I checked the brakes and I am not losing any fluid there, is the master cylinder bad? Should I just bleed them?
Old Jan 4, 2003 | 12:59 AM
rx-7fc's Avatar
can you see brake fluid under the master cylinder because thats where it starts to leak from when it goes bad
Old Jan 5, 2003 | 11:41 AM
I can't really see any, how much does one run?
Old Jan 6, 2003 | 12:00 AM
rx-7fc's Avatar
look here http://www.mazdatrix.com/j-3brake.htm
Old Jan 6, 2003 | 12:01 AM
rx-7fc's Avatar
it says $122
Old Jan 6, 2003 | 12:06 AM
artowar2's Avatar
Seems to me that you'd want to check all of the lines & fittings, from the calipers all the way back to the master cylinder....
Old Jan 7, 2003 | 12:57 AM
no luck everything seems to look okay.
Any ideas? Is the master just bad?
Old Jan 9, 2003 | 01:46 PM
Could my pads just be at the end of their life?
Old Jan 10, 2003 | 02:23 AM
artowar2's Avatar
Hmmm, well as your pads wear, your fluid level in the master cylinder will drop. The way you worded your original post, I though you were saying that you had a leak. But reading this thread again, I'd suggest checking your pads too.
Old Jan 10, 2003 | 08:41 AM
Travis R's Avatar
trying to build a racecar
You also might look under your dash. I had a master cylinder go bad that was leaking from the back side where the brake pedal pushed against it. I didn't know where the fluid was going until I pulled back the carpet and saw all the stripped paint.
Good luck
Old Jan 10, 2003 | 06:43 PM
Thanks guys, with my strange hours I haven't been able to check during daylight. I've been restricted to cruising the 83 VW Westfalia, what a beaut!
NCross
Sep 3, 2015 03:42 PM
fastsaab
Aug 19, 2015 11:42 AM
Frisky Arab
13
Aug 18, 2015 05:30 PM
Marty RE
Aug 13, 2015 11:19 AM
