Buying a parts car
Old Aug 9, 2001 | 03:35 PM
BlackR1's Avatar
Meesto Spakaro
Question Buying a parts car
Im in the process of buying 2 FC's, one for parts, and one to install them all into.
The 1st one is $1000, has a working engine, good body, suspension, 16 inch alloys, no PS, AC, or interior. The other car is a 10th Anniversary for 1600, everything works but the engine is about to go out...needs some body work.
What's the median price for rebuilding an engine with a streetport? I want to create one good running car, and then maybe try rebuilding the spare bad engine myself just for experience
Old Aug 9, 2001 | 06:11 PM
live4boost's Avatar
AKA ShepFC3
Are you going to use it for track? I the first one a TII? what year? The price all depneds on what you want to do when you rebuild the car. If your going for pure track you will be dropping a few bucks.
Old Aug 9, 2001 | 07:38 PM
BlackR1's Avatar
Meesto Spakaro
Something to have as a nice daily driver, with some 'spirited driving' mixed in. A good reliable stablemate for my FD that will hit low 14's without costing too much. Im not too well read on the 2nd Gens...is it possible to put the turbos from the TII on the NA engine that will be rebuilt and dropped into the 10 AE?
Old Aug 9, 2001 | 07:43 PM
cymfc3s's Avatar
I Raise Chickens
Be carefull. TII's have a way of making you spend a ton of money on them. =]
Old Aug 10, 2001 | 12:16 AM
rx7_ragtop's Avatar
From: Ft. Worth, Texas, USA, Earth, Solar System...
Technically, YES, with some modification/adapters/etc. Realistically, NO... it isn't worth the effort. Rebuild the TII motor. An NA parts car is good for body and interior parts- everything else on the TII is "upgraded," unless it happens to be a 5-lug/4-piston car, in which case the brakes and rotors are also the same. Oh... control arms, subframes, that kind of thing are the same too... but not springs, swaybars, transmissions, differentials, driveshafts, axle shafts, clutches, slave cylinders, starters, wiring, etc. Don't waste your time with an NA for parts unless it is just for body parts... in which case, $1000 is a rip-off.
Brad
Old Aug 10, 2001 | 12:58 AM
BlackR1's Avatar
Meesto Spakaro
ahhh i see...Thanks for the heads up!
Old Aug 10, 2001 | 01:03 AM
Scott 89t2's Avatar
SOLD THE RX-7!
I'd just buy the 10th ae and get a new engine put in. $2-3k? a non turbo parts car is almost useless. everying on the engine and drivetrain is different. including the engine itself.
plentymoon
NW RX-7 Forum
Sep 5, 2015 08:55 AM
cam_7779
Aug 18, 2015 07:48 AM
Engine stand ready
Aug 14, 2015 10:26 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
