Spring Rate?????????
Old Dec 26, 2002 | 01:12 AM
BlackRx7's Avatar
Daily Domestic Killer
I just got some linear Suspension techniques 1" lowering springs and I was browesing the mazdatrix website and saw the spring rate
check this...
FRONT
Manufacturer Rate
Stock 95
Racing Beat 130
Suspension Techniques 120
Eibach 70/185
REAR
Manufacturer Rate
Stock 90
Racing Beat 80
Eibach (non-Turbo) 85/165
Eibach (Turbo) 90/165
so is the same spring rate better to be the same all around or varied, I guess you can always adjust your strut braces.........
Old Dec 26, 2002 | 01:28 AM
Makenzie71's Avatar
...94% correct.
not necesarrily...if you're unsure about what you're doing then you prolly will not go wrong with a totally equal setup.
But the varying spring rates at the corners changes the driving characteristics of the car. For example...(keep in mind that I may be thinking about this backwards here) if you have a higher spring rate in the front and a softer rate in the back your car will tend to understeer when pushed. Has to how bad depends on the how soft the rear is. Now if you have a softer front and a high rate in the rear you will tend to oversteer. The rates you want really depend on what exactly your driving style is.
Note: Higher rate in the rear=good drifting
good way to get an idea of this is by playing Gran turismo in the same car with the spring rates adjusted.
Old Dec 26, 2002 | 02:01 AM
suprfast's Avatar
whoa, im a third gen guy so call me ignorant when it comes to second gens but are those spring rates correct. seem really soft for stock. i think the third gens are three times that. could also be that i could care less about stock rates and always want more. ditch the cadilac ride ill take bulldozer feel.
kris
Old Dec 26, 2002 | 12:54 PM
BlackRx7's Avatar
Thanks direct from the Mazdatrix web site......but I always though 3rdgen had a better ride...
Old Dec 26, 2002 | 01:06 PM
Snrub's Avatar
kris
Shut up you know it eats us FC guys up inside.
You want it stagered. For example, k2rd's coilover setup uses 350f/225r.
zyph3r
Canadian Forum
Sep 16, 2018 07:14 PM
He's On Toroids
NE RX-7 Forum
48
Oct 19, 2015 08:58 PM
inMotion719
Sep 28, 2015 03:09 PM
