pull to the right
Old Dec 25, 2002 | 01:56 PM
ttb's Avatar
ttb
No Cup Holder Racing
pull to the right
my car has a slight pull to the right, especially speeds of 80mph+. i've gotten it aligned, the tires are brand new. what else could it be? just something wrong with steering? bc i can see it tilt to the right a little at high speeds. thanks.
Old Dec 25, 2002 | 06:19 PM
neevosh's Avatar
The Dude Abides
Check your tire pressure.
Old Dec 25, 2002 | 06:25 PM
ttb's Avatar
ttb
already did
Old Dec 25, 2002 | 07:04 PM
spoolin93r1's Avatar
this may be weird but if you have a front spolier, check the screws that hold it in, if the right side is loose causing the spoiler to point more downwards and apply more downforce to the side, then that could cause it. only thing i could think of that would be speed dependent
Old Dec 25, 2002 | 07:10 PM
Johnny's Avatar
OG
you said aligned...but that has nothing to do with balancing of the wheels itself...only other thing I can think of
Old Dec 25, 2002 | 07:14 PM
ttb's Avatar
ttb
this pull happened with my previous set of wheels/tires also, that's why i don't think it has to do with the wheels/tires...doing 80pmh i can literally see the steering wheel turn to the right a little...could it just be something in the steering mechanism?
Old Dec 25, 2002 | 08:48 PM
Aristo's Avatar
I have the exact same problem...steering wheel displaces slightly to the right if you let it go in the highway..Ill try to get an alignment on Friday.
Old Dec 25, 2002 | 09:13 PM
MattRX7's Avatar
Did you install the tires yourself? A couple of years ago I bought new tires (Dunlop 5000's) from NTB. Got the car back and started driving it. The car pulled very hard to the right. Much worse than you are describing. I figured they somehow screwed up the alignment or something. After many return trips, the idiots finally realized they put a different size tire on the right side from the left side. I never even thought to check that, I mean putting on tires isn't rocket science. I don't think this sounds like the same thing that is happening to you, but its another thing for you to check. Even if they are the same size, you might want to swap them and see if it pulls in the other direction. Could be something wrong with the tires.
Good luck,
Matt
Old Dec 25, 2002 | 10:02 PM
jr426's Avatar
Do you know the spec. of the finished alignment (camber and caster of both sides) also try swaping the front wheels (side to side) and check the front and rear suspension for any looseness.
Old Dec 26, 2002 | 09:16 AM
Scrub's Avatar
bow leggin'
one of your wheels could be bent also, have you checked the inside of the wheels?
Old Dec 26, 2002 | 09:47 AM
Turbonut's Avatar
As long as car was never in an accident, I have seen alignments done with equipment that the shop feels is in specs, however, even though the readings appear as within tolerance, the camber is out on one wheel. Check the tires closely, especially the right front for any sign of wear on the outside. One experience-I had a Buick, and Cadillac aligned by the same people. A little while late both experienced wear on left front outside. Took if back, but it on rack, and read perfect. Went to another shop and camber was way out on left side. I've also seen cars that wheelbase (measurement from center of front wheel to center of rear wheel) differs from one side to another, indicating a front wheel trailing, causing a pull.
Old Dec 26, 2002 | 02:27 PM
ttb's Avatar
ttb
thanks for the inputs...will try them when I get back from LA.
Old Dec 26, 2002 | 04:07 PM
ACTION RT's Avatar
G35 FTW
check the ball joints..if there bent a mm or 2 then it will pull..
my beater had the same problem, i guess the ball joint was bent a tiny bit so it pulled a bit to the right at any speed.. then I hit a curb yesterday in it, and bent the ball joint up even more it pulled like a bitch to the right
so i went and got a ball joint from mazda for $78CAD with tax, my dad put it on.. and now it doesn't pull anymore.. i need to get an alignment tommorow though to make it "accurate"
Old Dec 26, 2002 | 04:27 PM
rx7racer11's Avatar
i had similar problem... mine slightly pulled it was aligned and everything.. turned out my control arm was bent ever so slightly ..
Old Dec 26, 2002 | 05:39 PM
GoRacer's Avatar
Speed Mach Go Go Go
Mine has a slight constant pull but really more noticable the faster you go. I've had it aligned several times and have had several race shops look at it and they all tell me there is no pull and it's perfect, wtf? ...Bullships!!! If you hold the wheel with the lazy two finger left hand on your left leg grip, you can feel the pull. If you hold it with your whole hand or both, you can't. If you let go it slowly tries to make a right hand turn.
I bet it's a slight bend in either the control arm or ball joint that can't be seen by the eye but aren't there machines to test that?
Oh and I was told to have a race shop do the alignment and not a tire store.
Old Dec 26, 2002 | 06:27 PM
ttb's Avatar
ttb
well i feel better that i'm not the only one...normal driving you can't really tell...it's only when you're going fast and you let go of the steering does it show. oh well.
squirrels
Sep 1, 2024 09:52 AM
rotor_veux
Sep 28, 2015 09:25 PM
Jingkun
Sep 28, 2015 01:53 PM
lnlreaper
Sep 27, 2015 09:59 AM
