Door Handles
Old Dec 22, 2002 | 07:59 AM
actionhank's Avatar
Door Handles
Any one know where I can find a brand new door handle? Mine broke on thursday and I would like to replace it new if I can. I figure if I buy used its just going to break on me again a lot sooner than I would like.
Any takers? Thanks guys.
Old Dec 22, 2002 | 08:02 AM
onefastrx7turbo's Avatar
Merovingeon
Veteran: Air Force
You should be able to order it through mazda. Mine broke at the JCI place (the JCI guy broke it). All i need to do is bring my title down to the Mazda dealership and he will order me a new one with my lock already installed, no swapping. try that...
neil
Old Dec 22, 2002 | 08:18 AM
manatecu's Avatar
I would get a used one from JP, try jason at JT-imports. The reason it probably broke was from age and no oil. Mine tend to lock up each winter. By lock up I mean get tighter. I remove from the door and spray a little WD-40 on the springs and latching mechanism and they work great. This winter I tried something new Lithium Grease it seems to be working better.
Chris
Old Dec 22, 2002 | 01:46 PM
bigmack000's Avatar
Rotor DEMON !
yah mine alos broke you can install it your self just get it from mazda mine cost me 250 can$ but that is alot better then getting in the pass side to open your drive door
Old Dec 22, 2002 | 03:40 PM
suprfast's Avatar
just replaced mine. it too broke and i was doing the getting in the car from passanger side deal. sucked ***. well i payed about 195+ tax for mine and it was worth every penny since i dont have to do that crap anymore. if anyone is interested i now get employee at mazda dealerships. ill see what i can do
kris
Old Dec 22, 2002 | 05:00 PM
actionhank's Avatar
that works for me. I just need a handle. Manatecu, yeh i noticed that too.. i wasnt smart enough to pop it open and spray it..... Thank everyone for the help. suprfast, let me know about the handle my man. thank you
Old Dec 23, 2002 | 01:26 PM
Dragueur's Avatar
mines broke too!
Old Dec 23, 2002 | 01:55 PM
rizzxx7's Avatar
DIGG7ER
pos handles why didn't they just make a little more reliable...that junk is so flimsy i'm scared to open my door cuz i only got 1 good 1 left
Old Dec 23, 2002 | 10:56 PM
aReX-7's Avatar
Sounds like you guys want to drop the big bucks on new stuff, but I have a wrecked '93 in the garage with about 90K that has good door handles. I would sell them for $50 each shipped, or $90 for the pair. Should be able to just swap out the lock cylinders so your key will work.
I haven't had any break on my FD's, but I know they can be a problem. PM me if you are interested.
Jeff
Old Dec 23, 2002 | 11:02 PM
suprfast's Avatar
guys, i can get them for about 150ish brand new + tax. i cant get away from the tax sorry. also five bucks for shipping . let me know if you are interested. im not in this to make money, just to help out those who have helped me in the past. let me know. if i can get enough of them im sure i can pursuade the guy to go a tad lower. they all work off commission just like i will be at toyota. i know what that have the ability to do, only im better
kris
Old Dec 24, 2002 | 12:26 AM
apeiron
IM ghetto
Yea,
about a month after owning my car, the handle broke off because it locked up so I just gave it a little bit harder of a pull and SNAP..... I didnt want to pay 250 nor did I want to go through the passenger side door..
What I did, was drill a 3mm hole in a specific area, where the plastic part on the handle joins with the plastic part that tugs on the open mechanisim..... its confusing but I made it work after about 3 hours of looking at it.. I screwed a normal screw in, dremmled off the end, sanded it, bondoed it and painted it
looks decent, not noticeable other than by me... and it works great, I can tug the **** out of it and it stays strong !!!!!!!!!
I have met yet another broken handle problem now that isnt as easy to fix. The freaking glove compartment handle broke off... and this one wont be so easy, I'm pissed.. if somone has one for sale pm me pLZZZ!
Old Dec 24, 2002 | 02:54 AM
BATMAN's Avatar
Re: IM ghetto
ROFLMAO **** if it isnt one thing its the other.. u guys ever herd of takin it easy on a 10+ old car. jeeze...
ROFL glove compartment.. ROFL thats a good one.. good luck to ya
Old Dec 24, 2002 | 11:28 AM
aReX-7's Avatar
That is a really good price for a new handle. Good job Superfast. That is sweet
Jeff
Old Dec 24, 2002 | 11:43 AM
actionhank's Avatar
So suprfast, When can i get one of these handles from you?
Dragueur's Avatar
anyone KNOW how to replace the LOCK on it so u dont have to get a new key??
is it HARD? ( I have new HANDLES with their OWN locks )
Old Dec 24, 2002 | 12:00 PM
Jedon's Avatar
Slave2TheFD
I have a used passenger and drivers side door handle assembly for $75 each if anybody wants to go that route.
Old Dec 24, 2002 | 12:04 PM
turbojeff's Avatar
Do it right, do it once
I've seen handles break too. Usually the problem is the handle mechanism is really dry/no lube.
It is really EASY to lube the handle linkage and hinges. Pop off the inside cover to the handle, just pulls right off. Remove the two 10mm nuts, the handle will flop out of the door. Becareful not to let it scratch the paint. Move the handle a few times and notice where it pivots, etc. You can use motor oil or white lithium grease (available in a spray can at the parts store). The oil works better faster, the grease works longer.
Button everything back up!
Give it a try, you might be surprised how well the door handles will work after this. You can do both sides in probably 10-15 min TOTAL. It is really easy.
Jeff
Old Dec 24, 2002 | 01:23 PM
apeiron
why handles break
Actually guys.. I know ther reason the handles lock up. I spent about 3 hours looking at my whole door mechanism... There is a plastic part inside, that is supposed to keep the handle from going all the way shut.... Hard to explain, it keeps the spring mechanism from straigtening out and keeps it a little bent so its much easier to pull when its bent then straight and the force applied is different.... but, to sum it up. There is a plastic part that after years of abuse gets worn down or can even break off, I fixed this by putting a tiny screw in place of it to hold the metal part that controls the handle to spring, I have no grease or any wd-40 on the mechanisms and it works great... if you take it apart you will understand what Im talking about. Its realy easy to get to the mechanism.
Old Dec 24, 2002 | 01:44 PM
Dragueur's Avatar
yeah...and my door lock mechanism on the INSIDE broke too..that spring wont come up all the way to unlock the door.
Old Dec 24, 2002 | 01:55 PM
rizzxx7's Avatar
DIGG7ER
Re: why handles break
i've looked at this for hours at a time and i get stuck in a dead end everytime
Old Dec 26, 2002 | 02:03 AM
styxx8602's Avatar
You guys think going through the passenger door to open your car is bad? Well i was doing that for aabout two months when one day i broke the drivers door handle and had to get threw the hatch!!!!!!! Yes the hatch. The next day i got my lazy *** up and bought the drivers door handle.The passanger handle can stay broken for a while!
Andres
Old Jan 6, 2003 | 12:03 AM
Graziano's Avatar
Hi Kris (Suprfast), MY Driver's side door handle just broke 15 min ago!... F--K!! Over time, it was progressively getting tighter, and I lifted it up with too much force...and SNAP! My keyhole is also very gritty/sandy hard turning also(broken white flap)....would like to replace it too.
I would like to replace my driver's side door handle at a reduced cost. If it's not too late to help me out too, I would greatly appreciate it! You can email me at rockygraziano@comcast.net. Is this an easy job to do myself?
It seems it's one thing after another with my 94 FD.....getting depressed. I need a new radio, oil sensor, new belts, has low idle, and my Greddy muffler is always popping when I let my foot off the gas at low speeds, and ever since I replaced my antennae mast, it's been makeing a horrible screeching noise...it's embarrasing. Constant F--CKING problems.
Anything you can do, would be very helpful and and greatly appreciated. Thanks so much.
Wayne
Old Jan 6, 2003 | 01:34 AM
bureau_c's Avatar
Hey Dragueur,
I don't know if you ever got an answer or figured it out for yourself, but this is very easy to do. After 3 repairs w/ JB Weld, each one holding less time (initial repair lasted over a year by the way) I finally gave up and ordered a new one from Mazdaformance
Mine didn't come with new lock cylinders, but basically the cylinder is just pressed into the hole and held in place with a little clip. The only thing I would say is pay attention to the orientation of the cylinder, because for some reason it wasn't immediately obvious to me how it was supposed to go in.
jds
