fubared electonics
Old Aug 7, 2001 | 05:12 PM
Fingers's Avatar
Angry fubared electonics
My damn electronics in the car are upsetting me beyond belief. The stock security system works sometimes, but not others (although, this isnt worrying me much since i have an aftermarket system as well, and the stock alarm worked intermittently even before i installed it). A coupel of days ago, it developed another problem... the seatbelt light was on even with the car off and key out of the ignition!!!! WTF!!!!!!!!!!!!! My horn is the other problem. Its quite intermittent as well... Any ideas?
Old Aug 7, 2001 | 06:00 PM
vaughnc's Avatar
knowledge junkie
Harness grounding possibly. If you don't see a patern and the car runs good, then try starting with the major fuse blocks. Also check the battery ground.
Otherwise, you'll have to get ye old volt/ohm meter out or have an rx-7 shop do it for you.
Old Aug 7, 2001 | 11:03 PM
RETed's Avatar
Re: fubared electonics
It could be your door switches are corroded.
This is a new one...
The "CPU" has bad solder joints in it...
-Ted
Old Aug 9, 2001 | 11:11 AM
Fingers's Avatar
The door switches have been replaced a few weeks ago and they work fine, i thought it was the problem too. The CPU stuff... i'll have to solder that, dont i? and the ground link... i replaced all my grounds with 4 gauge high current wire. So i dont think that's it. Any other ideas...?
btw, thank you everyone for replying. and ted, you're one of the most knowledgeable people when it comes to 7's... cheers man
Old Aug 9, 2001 | 11:27 AM
SureShot's Avatar
Seduced by the DARK SIDE
When I got my 87, it had multiple electronic problems. I spent about 16 hours resoldering the connector joints (where the larger parts are connected to the circuit boards). I also cleaned the horn relay contacts (in the CPU module). Search for the “cold solder joints” posts. That fixed everything you describe. Just a heads up: The wiper switch relay will probably wear out soon. A new one can be soldered in.
Old Aug 9, 2001 | 12:28 PM
Fingers's Avatar
hehehe funny you should say that. the wiper switch HAS failed. Although, an aftermarket switch has been installed by the previous owner, and it doesnt bother me one bit. thank you for the reply
-Ross
FDNewbie
46
Dec 12, 2005 11:43 AM
mikey D
13
Feb 17, 2005 07:46 PM
mikey D
1st Gen Archive
13
seanfd3s
Jul 20, 2004 05:38 PM
rotarynews.com
May 3, 2003 11:41 PM
