How do you keep water outa monster port?
How does one keep water outa a monster port? do you just poxy everything together?!?!? how would you take the engine apart again then,..
You don't for very long. This porting was designed for racing where a peripheral port wasn't allowed but big power was wanted. The engine only had to last a race or so. They just use plenty of gasket sealer and pray. I wouldn't use that port style unless you have lots of time and money to spend on engines.
Should'nt really be a problem. Use sealant in the right places, at both the cut water seals and toward the water jackets and you should be find. Remeber when you go J-port and bigger you can upgrade the coolling system to run a lower psi than stock, or any port for that matter. Breaking the seal is only a problem if you did'nt seal it right, like scraped it or something. You could actually build a cooling system that did'nt have to be pressurized at all if you had enough frontal area. If there's no pressure, you can seal up anything! Ito, I really appreciated your help, I think I know what I'm going to do now.
monster bridge Judge
Hmm,.. you could use ngp+ and have no pressure,.. what kinda sealent do you use to seal them? regulay high temp gasket maker? silicon? - sorry i didnt reply sooner, my comp died, i had to go get another powersupply.
msilvia
15
Sep 11, 2015 12:13 PM
mulcryant
Sep 9, 2015 05:24 PM
