Sponsored by: CARiD
Differentail fill plug stripped HELP
Old Aug 6, 2001 | 11:09 PM
skold's Avatar
I was changing my differential fulid and after i had it drained i noticed that the fill plug is rounded off. i need help how else can i get fulid into it so i can drive it again
Old Aug 7, 2001 | 04:03 PM
Gene's Avatar
10 lb. boost, 5lb. bag
that blows. Get some vice grips and pull that sucker out. And don't put it back! Get a new one
Old Aug 7, 2001 | 04:08 PM
turbovr6's Avatar
ok first you need a hammer and a chisel or metal punch with a flat tip(like a flat head screwdriver blade) First use the punch dead on to make a slot in the plug towards the top of the plug not the center. then hold the chisel at a 45 degree angle at the slot you made. hit it a few times and it should start to turn.
Old Aug 7, 2001 | 11:13 PM
Henrik's Avatar
Vice grips all the way, the filler plug shouldn't be too torqued
and always, always, always take out the fill plug first when changing any fluids (of course you know that now )
Henrik
87TII
Old Aug 8, 2001 | 07:28 PM
skold's Avatar
Fixed
i used a basen wrench and it came right off
_Tones_
May 25, 2021 05:37 AM
ZacMan
Sep 19, 2015 09:20 PM
Skeeg
Sep 5, 2015 07:41 PM
