Installing hawk hps front pads...
Old Dec 6, 2002 | 09:19 PM
af908's Avatar
im trying to retract the piston back into the caliper as shown here :http://www.rotarypowered.com/howtobrakes.html
In the picture the 2 pistons to the right (farthest from car) went in fine but the ones to the left (closest to the car) wont go in no matter how hard i try. I can tell that the pistons on the right are in more then the ones on the left. WHen all the pistons are fully retracted, are the ones on the left (closest to car) supposed to sit out more then the ones on the right?
All this is bothering me because i can't fit the hawk pads and stock shims in there. When i bought the pads they came with a backing already attached to the pads. I'm supposed to use the stock shims in addition to this, right? Maybe this is my problem because without the stock shims i could probably fit that one pad in there....
thanks
Old Dec 7, 2002 | 03:42 PM
AJatx's Avatar
I didn't use the stock shims since the Hawk pads already have a shim on it and it's a snug fit without the stock shims. I went through this experience a few days before the first MSR event.
Both pistons can be pushed in flush with the boot. Just keep working it.
Some of the piston may go in easier than others.
Just keep working it with two screwdrivers or a c-clamp.
You can put the stock pad back in and press the brake pedal (remember to put the brake fluid cap back on). Sometimes, it helps move the piston a bit so you can push it inwards.
Hope it helps,
J
Old Dec 7, 2002 | 09:33 PM
af908's Avatar
hey thanks for the help.... unfortunatly i kept trying to force the piston back in and it kind of flatted itself out. So basically the piston now sits as high as the rubber boot instead of before when the piston would sit about 2 millimeters higher than the boot. Do you think ill be alright?? Good news is though that since the piston flattened itself out a little bit i was able to squeze the pad and shim in.....
Old Dec 7, 2002 | 10:24 PM
Carl Byck's Avatar
Mad Man
The best trick I've found is to leave the old pad in place, and use the C clamp against that.ususally when the piston won't go in it is because it is not exactly straight in the bore. Using the pad will help prevent this. Also you can drive two pistons in at a time Carl Byck
Old Dec 8, 2002 | 12:09 PM
af908's Avatar
yeah i used the old pad but instead of using a c-clamp i used a big wrench beween the pad and the old rotor to pry it
diabolical1
30
Jan 30, 2016 05:50 AM
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
