Can I just replace the plastic OMP lines with all rubber?
Old Nov 30, 2002 | 03:27 PM
RotorMotorDriver's Avatar
Seven Is Coming
Just as the title says. Would there be any problems? I honestly cant think of any, but you never know. I was thinking rubber or silocone. Any thoughts?
~T.J.
Old Nov 30, 2002 | 03:35 PM
FD Racer's Avatar
sold the FD...kept the FB
Rubber lines will hold a lot more oil in them. The stock plastic ones have a very small inner diameter. The larger you go, the more the lines will have to "fill up" before they will start to inject oil. Not sure if it makes a big deal or not.
Old Nov 30, 2002 | 03:37 PM
Seven Is Coming
Yeah, I thought about that. I was gonna try and find something to "exactly replace" the stock ones, just all soft line rather than the brittle hard lines on there now.
~T.J.
Old Nov 30, 2002 | 03:40 PM
FD Racer's Avatar
I've never seen a soft line with such a small inner diameter, it's probably only 2mm tops.
Old Nov 30, 2002 | 04:20 PM
Adsy01's Avatar
ACBron Motorsport
oil and rubber don't mix.
the oil will soften the line and cause them to swell.
have you ever seen a rubber bush that has been oil soaked for a long time??
the silicone lines should work fine though.
Old Nov 30, 2002 | 05:15 PM
MIKE-P-28's Avatar
Driven a turbo FB lately?
Yeah just make sure the rubber you use is suitable for the heat and the usgae of oil..
Old Nov 30, 2002 | 10:05 PM
Seven Is Coming
So if I find a silicone hose or a rubber hose "suitable" the "right size" I can use it?
~T.J.
Old Nov 30, 2002 | 11:21 PM
Directfreak's Avatar
I am a Jeeper Now.
~T.J.
Doesn't the 12A only have 2 of them? They are like 12 bucks each from the dealer. Don't risk it with some "home-engineering", use the right part if it exists.
Old Nov 30, 2002 | 11:25 PM
Adsy01's Avatar
ACBron Motorsport
~T.J.
yup for sure...
other options would be copper or steel line, but you still have to find a way of hooking it up i guess
Old Nov 30, 2002 | 11:38 PM
Seven Is Coming
So...On with the hunt to find the "right size" hose...In yellow of course .
~T.J.
Old Dec 1, 2002 | 01:07 AM
Seven Is Coming
But theyre not yellow . Plus i dont want them drying out and breaking over time like all my other ones.
~T.J.
Old Dec 1, 2002 | 01:08 AM
I am a Jeeper Now.
~T.J.
17+ years is pretty good if you ask me.
Old Dec 1, 2002 | 01:14 AM
Seven Is Coming
Yeah, good point.
Heres a question though...What do people running aftermarket carbs use for the OMP lines? Obviously the pre-formed factory lines wont fit, so what do they use?
~T.J.
Old Dec 1, 2002 | 01:27 AM
I am a Jeeper Now.
Yeah, good point.
~T.J.
Either they drill and tap, using some kind of braided hose, (not necessarily steel braided)
OR
Pre-mix.
Old Dec 1, 2002 | 01:28 AM
Felix Wankel's Avatar
Super Newbie
I took mine off and smashed them with a hammer.
Old Dec 1, 2002 | 01:54 AM
Seven Is Coming
Ok...What size?
~T.J.
Old Dec 1, 2002 | 12:38 PM
gamble302's Avatar
roadkill hats rock
only cause your carb didnt come with the omp linkage
Old Dec 1, 2002 | 02:05 PM
Seven Is Coming
Haha, yeah. But seriously, what size should I get?
~T.J.
Old Dec 1, 2002 | 05:18 PM
mperformance's Avatar
I'm using the stock OMP lines with a weber carb...you can use them without any problems. I suggest you get them new and try to use them with your aftermarket carb.
My 45DCOE came with copper tubes tapped into the jet cover and I just placed the original OMP lines to it. They are a bit bent but not so much that they will brake. BTW my carb is way down close to the header since it's on a lake city sidedraft manifold. I still have my original OMP lines.
You can also use copper lines used for oil pressure gauges, they sell those everywhere and I think the internal diameter is small enough.
Old Dec 2, 2002 | 02:19 AM
Seven Is Coming
Hmmm...Ok. Well I think Im gonna look into it more, maybe Ill find something interesting. I was thinking of using one of the sizes of silicone fuel line for model cars and stuff. That stuff is small, and fuel/oil resistant/proof, and they sell it by the foot. I just need to find it in the right size.
~T.J.
Old Dec 2, 2002 | 02:24 AM
FD Racer's Avatar
~T.J.
Now you're talking! Good idea.
FD7KiD
15
Feb 26, 2021 10:12 PM
BLK 93
Aug 19, 2015 03:47 AM
Leeroy_25
Aug 17, 2015 12:53 PM
