2 years sitting
Old Nov 26, 2002 | 02:41 AM
2 years sitting
Did the atf thing. put a full bottle down the pipe. cranked a few times as i put it in and let sit for 2 days. Started it and it looked like the steel plants smoke stack a full bore. Ran it for about five minutes at about 2000 rpms. When I let it idle it was still blowing white smoke like mad and there was a liquid that came out of the tail pipe the snow was also brown and there wer drops all over it under the pipe. Is that bad?
I am also having a problem with the plugs I tightened all four down pretty good and after running it t1 and L2 were loose again
any advice would be apreciated.
Old Nov 26, 2002 | 03:31 AM
nimrodTT's Avatar
all aboard!
Thermal expansion? I'd just tighten them up and it prolly won't happen again.
Old Nov 26, 2002 | 03:42 AM
Rotor13B's Avatar
Wassup!!
Dude!!! a whole quart? ROFLMMFAO!!!!!!!!!
I wish could see that thing in action, lol. No but seriously, I would be worried about the heat exchanger soaking up the atf and igniting itself. I think it's the heat exchanger anyways. I had this happen with gasoline once on a flooded car. The raw fuel got soaked all around the pipe with the cloth wrap on it and ended up igniting itself as soon as the exhaust got hot.
Old Nov 26, 2002 | 03:21 PM
no fires yet
have my handy extinguisher ready every time though
does anybody know if you can put a 81-85 distributor into an 80 engine?
Old Nov 26, 2002 | 03:43 PM
REVHED's Avatar
Hunting Skylines
Sure you can. You'll just have to do a bit of rewiring as the 81-85 ignitors are mounted on the body of the distributor.
Old Nov 26, 2002 | 03:45 PM
damon's Avatar
that has to be the funniest screen name I have ever seen! rotflmao
peace
Old Nov 26, 2002 | 07:03 PM
Project84's Avatar
Open up! Search Warrant!
Nice name man. But a whole quart is a little too much.
Old Nov 27, 2002 | 04:17 AM
kinda late now hopefully i didn't mess anything up.
the reason i'm asking is cause i lucked out this time, I had an 82 rx back about 6 years ago and none of the scrap yards around here had anything for me. Now one scrap yard has 3 1stgens and a 2nd gen.
the first gens are pretty much all there and the 2nd gen doesnt have an engine.
I want to hit them up for parts and try to upgrade what I can from the newer cars.
If anybody knows what is interchangeable and what i should grab while i can let me know.
Got the name from one of those battle bot shows, can't remember which one. My GF and I cracked up when they interviewed one guy who won his third giant nut.
I was hillarious they went to his house and he showed off his nuts. They said it just like that in the interview lol!
and the rest is history
Old Nov 27, 2002 | 04:24 AM
Oh yeah one other thing. I have a 5.0 stang that needs bodywork real bad, and the rx's body is almost perfect.
should I swap and would you guys still talk to me if I did?
Old Nov 27, 2002 | 04:58 AM
I keep forgetting what i wanted to ask, can i put a newer alternator on this car?
Old Nov 27, 2002 | 06:42 AM
MosesX605's Avatar
My wife bought me 2 RX-7s
The dizzy and alternator are bolt on upgrades for the older 79-80 cars. Both are worthwhile, as the 81-85 electronic dizzys are superior to the earlier 79 points and 80 elec. The alternator from 81-85 also eliminates the external voltage regulator from the older 79-80 model. Note that if you replace the dizzy, you need some ignition coils from the later car as well, because the '79 coils are insufficient to the task. (I'm not sure about the '80 coils) Regarding the motor swap, it has been done, by members of the forum, but I don't recommend it. The 12A rotary is capable of significant power on the cheap if you're willing to do some legwork yourself. As a rotary, the RX-7 is a car with unique character. As a 5.0, it's like millions of other Detroit iron-powered cars, albeit better looking than most.
Old Nov 27, 2002 | 08:50 AM
jbcobra's Avatar
I'd still talk to you, but hey I'm new here and the rotary magic hasn't fully immersed me yet. When the 12A in my 82 rotates itself into oblivion I'm planning on dropping in a 5.0. My other fun car is a Factory Five Cobra replica that weighs in at about the same weigh as the RX7. With a stock 5.0 it flat hauls ***. 0-60 in under 4.7sec. I'd love to have my seven do that. You might also want to consider a Factory Five kit for the Mustang or you could sell the Stang to a cobra builder and use the money to build up the 12A.
Old Nov 27, 2002 | 06:01 PM
Project84's Avatar
Hell no and Hell no
cristoDathird
28
May 30, 2019 08:47 PM
alphawolff
Nov 17, 2015 05:57 PM
