Idle keeps going up and down
Old Nov 25, 2002 | 05:29 PM
Rx7isthebest's Avatar
My idle keeps moving up and down from 1000 to 1500 in about 1 second intervals. What is going on?! It just started doing this today - before it would fluctuate more erratically but now it's more orderly. Help please!
Old Nov 25, 2002 | 05:41 PM
legendr36's Avatar
Could be few things.
1. clutch switch needs to be replaced
(I replaced mine, and everything was good again)
2. air pump might be dead
Try turning on your A/C, does it stop it?
Old Nov 25, 2002 | 07:52 PM
RX7SpiritR's Avatar
The Spirit of FLUFF!
mine does the same thing, help!
Old Nov 25, 2002 | 08:35 PM
No, the a/c doesn't effect it. Somone PLEASE help me, I am down on my knees!
Old Nov 26, 2002 | 12:30 AM
jumprdude's Avatar
Lower Intake Manifold gasket might be blown.
Have you had yours replaced yet? They came in paper form from the factory, later this became metal.
Old Nov 26, 2002 | 03:44 PM
jwhite94RX7's Avatar
I diagnosed a car with exactly the same symptoms recently. It was the LIM gasket.
On the car I looked at, the idle would settle down if you pulled the electrical connector off the air pump. Of course, if you leave that off, your air pump will die.
To diagnose an intake manifold gasket, spray carb cleaner around the gasket. If it smooths the idle, you've got a leak. The lower LIM gasket is tough to get to, even for just spraying to diagnose it. I attached a long, narrow diameter hose over the spray tube and tied the other end of the hose to a piece of coat hanger so that I could position the end of the hose around the LIM gasket.
Good luck!
Jim
Old Nov 26, 2002 | 03:50 PM
apneablue's Avatar
Good luck!
That's gonna be a PIA to change if you are planning on doing it yourself...BUT if you have all that stuff off already may as well have everything polished!
Old Nov 26, 2002 | 10:39 PM
djantlive's Avatar
I had my LIM gasket changed too. I delayed it for over a year until I had to get it fixed in order to pass smog (high idle). It's okay if you don't fix it as long as the leak isn't too serious. It's an expensive job $800 if you do decide to do it. I spend more money basically getting hoses replaces and other things while they are all off of the car.
Old Nov 26, 2002 | 11:39 PM
Actually, turning the A/C on fixes it! Do I really need to fix this problem cause I don't have any problem with running the A/C or heater when I drive (unless it puts some kind of extra stress on the engine).
Old Dec 26, 2002 | 10:28 PM
mikeclarkusa's Avatar
I have this problem. Squirting some lube on the throttle body linkages and shafts fixes it instantly. Stays fixed for a few weeks or so.
I don't know if the lube is freeing up the sticking linkages or if it's sealing a small air leak.
Old Dec 27, 2002 | 10:47 AM
af908's Avatar
my idle also fluctuates but its only right before its warmed up... once i drive it then i let it idle its fine..
Old Dec 27, 2002 | 11:27 AM
apexkw's Avatar
in slow, out fast!
ok what about me? i dont have an airpump i am single turbo and i replaced the lim gasket with a metal one when i did the turbo install. i have tried to adjust the throttle and i have sprayed everywhere looking for a vacuum leak but i just cant find one. i just cant figure it out. also my car will idle at 2k sometimes and sometimes it will be normal. then when it feels like being retarded it will idle hunt like a **** almost stalling and then reving again.....arg thanks for any help
john
dona1326cosprings7
Oct 29, 2015 06:47 AM
LongDuck
Oct 7, 2015 08:12 PM
Einheri
Oct 7, 2015 12:23 PM
93FD510
Oct 1, 2015 02:00 PM
Jmpabon93
Sep 30, 2015 04:57 PM
