Coolant
Old Nov 25, 2002 | 05:16 AM
9413Btt's Avatar
Thumbs up Coolant
I have to top up my coolant every 3 weeks. Is it normal for a FD?
The story goes like this, initially, my coolant light came on, so I top it up thinking that it is just the time to top up. BUT 2 to 3 weeks later, the light came on again so I top it up again. This time, I suspected that there might be a leak. So I check the coolant level for 3 days (without driving the car) but the level remained the same. So what can possibly explain this? Help.
Old Nov 25, 2002 | 06:17 AM
Rated R1's Avatar
Oji San
Pinhole leak or a bad o-ring. Have your system pressure tested.
Old Nov 25, 2002 | 08:52 AM
apexkw's Avatar
in slow, out fast!
turn your car on and look in the engine bay. sometimes you will be able to see it leaking. just like what rated r1 said... a pinhole leak will only leak under pressure.
Old Nov 26, 2002 | 04:17 AM
9413Btt's Avatar
Thanks, but which o-ring are u referring to? Will this damage my engine if i leave it unfix?
Old Nov 26, 2002 | 05:37 AM
Rated R1's Avatar
Oji San
If it is the o-rings (coolant seals) you are looking at a new engine my friend.
Old Nov 26, 2002 | 08:16 PM
9413Btt's Avatar
oh no.......
Old Nov 26, 2002 | 08:17 PM
9413Btt's Avatar
is there any way i can find out if it is the o-ring or juz a leak?
Old Nov 26, 2002 | 08:18 PM
Tom93R1's Avatar
gross polluter
check/replace the pressure and non-pressure caps too. I had similar problems that ended up being from a bad non-pressure cap.
LongDuck
Oct 7, 2015 08:12 PM
musker
Oct 1, 2015 05:58 PM
ZaqAtaq
Sep 5, 2015 08:57 PM
