3rd gen rear strut bar with tein flex setup
Old Nov 18, 2002 | 03:08 PM
mkoch1's Avatar
For those of you with the tein flex set up or thinking about buying one, the manual says you have to remove the rear strut tower bar to fit the motors on. After a little cutting I manage to keep the bar and mount the motors. The car has a full cage so the bar probably isn't necessary, but it holds the sub box in place. Though this may help out some of you.
Old Nov 19, 2002 | 06:41 PM
neofreak's Avatar
accept no imitations™
What about the front? Does it work with a STB?
Old Nov 20, 2002 | 10:38 AM
mkoch1's Avatar
It should work fine up front with any strut bar.
You may have hood clearance problems. I have a boarder vented hood and it fits fine. Their site says that on the stock hood you may have to cut away the insulation.
