Will this work...
Old Nov 16, 2002 | 04:30 PM
DavidDeco's Avatar
I have more fun than you.
Will this work...
Yup another one...I did the search and have come up with following, I just want to be sure
Volk GT-C
: 18x9" front offset around +40 ?
: 18x10" rear offset around +38?
I have Tokicos and Eibach springs all around. I was planning to use PP S-03's 285/30-18 Back, 255/35-18's front.
Do I have it right?
[If anyone out there can get the Amemiya AW7's in 18" (Gold preferably) sometime this century, I'd still be willing to get them by the way...]
David
Old Nov 17, 2002 | 01:54 PM
mp5's Avatar
mp5
It sounds like it would work in the front
You "may" have to roll the fender in the rear depending on how low your running because of the low offset.
C.
Old Nov 17, 2002 | 10:38 PM
jr426's Avatar
GT-C rims have two face styles and three pad hights. 18x9s are available in +42 in both face types, with high pad hight ( caliper clearance).These should fit with your tires but you may need to roll your fenders. 18x10s are available in +37, +43, +50, in face 1 with a mid hight pad and a +47 in a low pad hight. I don't know if a low pad will clear the caliper in back. In a face 2 they come +37 in mid pad and +44 in low pad. I wouldn't run the 37 in back, others on the form have used +43 in back but have used 275-35-18. Contact ARD T2 to help with fitments, you most likley will need to order them (8 weeks) so spend the time to order the right ones
Old Nov 18, 2002 | 04:20 AM
ARD T2's Avatar
jr great work. I only recommend the +40 on the 9"er as a last resort, due to lack of offset options, and limits your front tire sizing to a 245/35 max in the 18" diameter. While that is great, it is not an easy size to find relatively speaking.
If you have higher offset options the better. The first thing I'd like to know is what type of suspension you are running. If it deems I would like to see if we can run the
Mid pad type:
18,9 +50 face I
18,10 +44 face II
If all goes well we can run 255/35 and 285/30 which are easier sizes to get in the same tire model. Let me know the suspension stuff and we'll work through it real quick.
Thanks, Rishie
Old Nov 19, 2002 | 09:51 PM
DavidDeco's Avatar
Originally posted by ARD T2
j
Thanks, Rishie
Thanks, I thought I did post my suspension mods that were relevant.
I PM'ed you the full deal. It's Eibach springs, Tokico 5 way illuminas, and some stuff like front sway bar (RB), Pettit street launch kit and fr/rear strut bars.
Old Nov 20, 2002 | 03:09 AM
ARD T2's Avatar
Cool
Easy enough.
Rishie
A_Shadow
Comments and Suggestions Archive
Sep 1, 2015 06:31 AM
music_addikt
Interior / Exterior / Audio
Mar 30, 2004 06:45 PM
enigma32
Mar 29, 2004 08:33 AM
kiker14
Jul 24, 2003 01:21 AM
ped
Oct 10, 2002 04:44 PM
