what injectors to run on a 91 13bt with a BNR stage 2
Old Nov 15, 2002 | 09:59 AM
82streetracer's Avatar
8/1 Building/Drive Ratio
i have a 82 with a 91 13bt going in with a BNR stage 2 to4e turbo and a big front mount.
i want to run about 12-15lbs of boost to start with, I dont plan on going past 18-20lbs.
Im thinking the standard 1600s of the secondarys and move the stock 800 secondarys (right??) to the primary.
does this sound good.
also, what fuel pump would you recommend. It will not be a internal pump as I have to use a GSL SE tank or a cell. I have heard people recommending a Bosch pump but I couldnt find any info in my search.
Old Nov 15, 2002 | 10:46 AM
Josepi's Avatar
Despise Enmity
A 91 13BT should come with 4x550cc injectors all the way around. The only bigger stock injector is the 680cc from the GSL-SEs.
Old Nov 15, 2002 | 11:33 AM
Directfreak's Avatar
I am a Jeeper Now.
Fuel Injector Calculator
Old Nov 15, 2002 | 12:05 PM
bkapold@aol.com's Avatar
I take it your running a stand alone ecu? But ya the 800 Prims and 1680 2nds would be the way to fly
Old Nov 15, 2002 | 08:33 PM
yeh, got a haltech on the way.
Im thinking of running the engine totally stock except for a upgraded turbo(mainly for cost but also for siplicity) and then go from there. This is my first experience with stand alone. so Im thinking this is a better route. then when I get a hand of tuning the system I can upgrade the injectors and start upping the boost.
thanks for the info,
what about the pump, I saw a aeromotive pump on summit but it seams way overkill, is there a cheaper alternative. i keep hearing about bosch pumps.
Old Nov 15, 2002 | 10:34 PM
Dyre's Avatar
Your Opinion is Wrong
The stock 800cc injectors from the FD are side feed and wont fit the FC rails which use top feed injectors.
The biggest 'stock' injectors you can get come from the GSL-SE's. Some had 2x680cc and some 2x720cc injectors. Low Impediance.
Old Nov 18, 2002 | 09:42 AM
hondah8er's Avatar
mazdaspeed 3 coming soon
all se's had 680's
Old Nov 18, 2002 | 11:05 AM
cool thanks
Old Nov 18, 2002 | 12:13 PM
hondah8er's Avatar
np
Old Nov 18, 2002 | 05:27 PM
Just get some 1680's and 850's and you'll be set
www.injector.com
MarrenMotorsports
Old Nov 20, 2002 | 03:26 AM
dvls-7's Avatar
Sick & Twisted
for stock like setup u can go with 4 720s they plug right in and it should do the job until u r ready to upgrade it.
Old Nov 20, 2002 | 09:59 AM
how much power can I make with 720s all around, and where can I get them.
I doute ill ever exceede 300hp or 14-15psi
Old Nov 20, 2002 | 06:18 PM
dvls-7's Avatar
Sick & Twisted
Ive seen guys posted that they have made 300-350 with the 720s.....as for gettin them u can try the rx7 store or rc engineering. Im sure there are other places but im not sure of them at this moment.
cristoDathird
28
May 30, 2019 08:47 PM
BNR34RB26DETT
42
Feb 28, 2018 11:27 AM
dkwasherexd
May 27, 2017 04:51 AM
sYnth.
Aug 19, 2015 06:27 PM
