Power FC Power FC Wire cutting!?
Old Nov 7, 2002 | 07:31 PM
tomaszjc7's Avatar
I just recently bought my power fc and i was going to hook it up, i got some instructions and i found out that u have to clip 4 wires. So i found the wires but i wasnt sure about clipping them cause i wanted to put the stock ECU back in for the emmisions test.
Anyway, so instead of cutting the wires i took a needle nose plyer and pulled out the little copper part on the ecu that goes into the harness. I pulled out the exact ones that matched up with the wire you have to cut. I read latter on that some place that sells them, cant remember the name right now, does the same thing. Do they just pull out the copper part too? Or do they take apart the ECU and remove from the inside? I tried taking mine apart but I stripped all the fucken screws!
Has anyone ever done this before? Did it work, were there any problems and how exactly does the shop that sells them remove the little copper pins?
Thanks for all your feedback.!
-TOM
Old Nov 7, 2002 | 10:47 PM
TwinTriangles's Avatar
What's an RX-7 ?
PFC 4 Wires!!
Dude, do not open the Power FC, just cut the wires and if you have to put the old ecu back in twist them back together...but do not open the PFC...
JDub
Old Nov 7, 2002 | 11:54 PM
duboisr's Avatar
Garfinkle cuts the wires and puts male female connectors on the wires so they can be rejoined if needed, easy ,easy.
Old Nov 8, 2002 | 01:46 PM
RX7SpiritR's Avatar
The Spirit of FLUFF!
Question
I thought the power FC just plugged in. You are talking about the apexi power FC right? It says no wire cutting at all just plug it in. Maybe I'm wrong not sure.
Old Nov 8, 2002 | 10:43 PM
duboisr's Avatar
RX7SpiritR you or the supplier must cut some wires ,it is in the directions. They are smog control thing.
Old Nov 14, 2002 | 09:06 AM
ttpowerd's Avatar
HARRRRRRRRR
That was what I was thinking of doing. Glad to hear I'm not the only one and that it worked well
Old Nov 14, 2002 | 10:23 PM
ech's Avatar
ech
Actually I believe it is more an idle control thing. Not smog. If you don't cut the wires then the PFC might not be able to detect whether you are running with or without electrical load and/or A/C. So you don't get the different idle speeds that you can set.
Or at least that's what I remember.
distr0
Megasquirt Forum
48
Mar 18, 2022 06:17 PM
streetlegal?
Mar 17, 2022 02:46 PM
The Shaolin
Sep 14, 2015 07:50 PM
befarrer
Microtech
Aug 22, 2015 05:52 PM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
