ball&spring instead of solenoid/stepper
Old Oct 31, 2002 | 12:00 AM
Poweraxel's Avatar
hey everyone..on my all ever quest to find the perfect boost controller for my single turbo, i think im tired trying different electronic boost controllers trying to get near perfect stable boost..ive tried all the name brands stepper and solenod units..while the HKS EVC seems to work the best for me i still get slight spikes on inital boost up which eventually settles down... im thinking of trying the turbo xs dual stage or the "halllman" ball&spring (boostcontroler.com) anyone have any experiences with either boost controller on the there external wastegates??
BTW: ive had this problem with all my different turbo kits/wastegates..even with the HKS GT wastegate
Old Oct 31, 2002 | 10:05 AM
80-CU.IN.T's Avatar
This is the boost controller that I will be trying. This setup is very similar to what my friends used in the late 80s early 90s before good electronic boost controllers were readily available and affordable. My project is now running and I set up a dyno date with XS for the 14Th. I am stile looking for am electric solenoid so I will be able to run 2 different boost settings. ( haven't had any luck yet )
I am also breaking my engine in now - Meaning I am not trying to make boost. This is very difficult almost impossible with the way I set up my RX6. I ported the exhaust turbine housing and then had it extrude honed. I did a bunch of other sht too. So we will see the outcome. "I will post when I get my numbers."
Personally I think electronic boost controllers are the way to go now adays. ( They have come a long way since I have played with turbos in the early 90s.)
Old Oct 31, 2002 | 10:41 AM
cewrx7r1's Avatar
Eye In The Sky
I just replaced my Hallman with a Blitz Dual SBC on my non-seq engine. The reason, boost spiking around 4500 rpm when boost was increased from 12psi to 14psi. I tried different bleeder jet sizes but it did not help.
Unfortunately, the Blitz had to be returned because it was defective. As soon as boost went above 1psi, the unit would turn off. Go figure that????
If you want it, $50, contact me.
Old Oct 31, 2002 | 11:17 AM
WorkS2R's Avatar
I have an EVC Pro, I dont get the spiking like the EVC 4, at least not so far..
Is it only during initial?
Old Oct 31, 2002 | 11:45 AM
Astro's Avatar
Hmm..mitch you're having problems with the evc pro?
I have the evc IV SE...i hope i dont have too many issues with it!!
My friend uses it in his t51 powered supra and didnt seem to have spiking until he was over 25psi and at that point it was about 1lb over, sometimes under.
Old Oct 31, 2002 | 11:47 AM
vosko's Avatar
Just Call Me Terminator!
my blitz works good a little too well. i'm gonna play with it more. i might be switching to a greddy TVVC. those are rock solid
Old Oct 31, 2002 | 11:57 AM
Astro's Avatar
Yup, those greddy tvvc's are great, but i kinda want to have two (or actually 3..once you turn the ebc off) settings for boost.
Old Oct 31, 2002 | 12:03 PM
vosko's Avatar
i bought one used off ebay and guess what its BROKEN.... grrr.... for now i'm gonna use my blitz and see how well i can get it to work if i can't get it 100% i will order a TVVC. i know the TVVC work because i looked at the bullish racing six second solara's and what boost controller do they have ? TVVC
Old Oct 31, 2002 | 12:11 PM
yeah but those guys have a stepper clutch to put all that power to the ground. once your making really big power you should have an electronic boost controller so you can control boost per gear and per rpm. it'll help you out a lot w/ traction.
zyph3r
Canadian Forum
Sep 16, 2018 07:14 PM
He's On Toroids
NE RX-7 Forum
48
Oct 19, 2015 08:58 PM
inMotion719
Sep 28, 2015 03:09 PM
