My Dyno results...FINALLY!
Old Oct 27, 2002 | 09:37 PM
Roy Johnson Jr's Avatar
Boost Feels Good
Here are the graphs of my tuning session October 26, 2002:
This graph shows my horsepower being achieved at a 12:1 air/fuel ratio at 17 psi. We wanted 11.4:1 under boost, so fuel was added. Notice in the graph how the run was halted well before redline. 460-470 rwhp was expected here if the run had continued.
Here is a graph at 1 bar of boost (14.7 psi).
Here is a graph at 17 psi - what I run on the street.
Old Oct 27, 2002 | 09:48 PM
Silver7's Avatar
They are some nice numbers! I'm still amazed that even with a large turbo and street porting, the power drops off at around 7300 rpms. I would think it would build power till at least 7500 rpms.
RICE RACING's Avatar
You have to be happy with that
Old Oct 27, 2002 | 09:49 PM
Resource's Avatar
I think he said he left off the gas at the higher rpms that's why you see the dropoff.
Old Oct 27, 2002 | 09:52 PM
allrotor93's Avatar
tuning
what engine management do you have? who does your tuning?
Old Oct 27, 2002 | 09:54 PM
Boost Feels Good
I'm using the Power FC and Datalogit. Ed Snef tunes my car. www.engineered.net .
Old Oct 27, 2002 | 10:25 PM
allrotor93's Avatar
fuel
care to share a map with me!! noone around here tunes cars. what fuel system are you using?
Old Oct 27, 2002 | 10:30 PM
Resource's Avatar
Share the map.
Old Oct 27, 2002 | 10:36 PM
Boost Feels Good
You can see my mods at www.royjohnsonjr.com .
I will share the map.
Old Oct 27, 2002 | 11:20 PM
Badog's Avatar
Nice run, Roy!
Old Oct 27, 2002 | 11:24 PM
Badog's Avatar
More importantly Roy, share the logged session that goes with some of those runs (Datalogit log files). If you want some pretty graphs whiped up, I can do that and post them here.
And, unless you're running a 3-bar sensor, I think you might have been at less than 17psi according to the PFC. The data logs will show your boost. I am guessing you might have been at 16.8psi (most I every saw out of the standard 1.5bar sensor).
Old Oct 27, 2002 | 11:32 PM
vosko's Avatar
Just Call Me Terminator!
i can't wait to dyno my car..... SOON!
Old Oct 27, 2002 | 11:36 PM
Badog's Avatar
(chanting)
vosko
vosko
vosko
(end chanting)
Old Oct 27, 2002 | 11:39 PM
vosko's Avatar
Originally posted by Badog
(chanting)
vosko
vosko
vosko
(end chanting)
wow i feel special chanting....
there is a mobile dyno 10 mins from my house... so probably gonna throw it on the dyno at low boost at first 10-12 psi... it is FULL RICH 10.00 on my wideband.... still pulls like a bat of hell though..... need to hook up my wideband to my haltech so i can datalog the AFR.... that will make my life tuning so much easier....
if i'm lucky i will have dyno sheets this coming week!
Old Oct 27, 2002 | 11:42 PM
Badog's Avatar
Did you some major named tuners still don't datalog their tuning sessions?!
Old Oct 27, 2002 | 11:45 PM
vosko's Avatar
i didn't know that. i have never asked anyone if they do it. i just assumed they did. why the hell wouldn't you want to datalog..... too lazy hit the button to start it ?? LOL
Old Oct 28, 2002 | 12:36 AM
Mr rx-7 tt's Avatar
rotary sensei
Roy,
Your first graph shows 17 psi (456) then your last graph shows 17 psi (439)..?
Anyhow, Great numbers....
Old Oct 28, 2002 | 01:02 AM
C-westin'FD's Avatar
Nice numbers!!!
Congrats!!
Old Oct 28, 2002 | 04:14 PM
Marshall's Avatar
They added fuel, chief.
Nice numbers, Roy! Question....why is it that all the american turbo companies bash the T-78 and claim the T-66 is so much better? Has anyone actually seen a T-66 put down similar or better numbers?
Old Oct 28, 2002 | 05:01 PM
pluto's Avatar
Re: My Dyno results...FINALLY!
Looks good Roy,
from looking at your first graph, it seems like you were running too rich in mid range and then at around 6.3krpm, it was running a little lean which (i think) causing your timing retard. Correct me if I'm wrong but i think your timing is a little advanced for 17psi at the higher rpm. on a side note, I think you were using a wideband at the exhaust pipe? becareful on that map, you'll run leaner when you are actually on the road.
Old Oct 28, 2002 | 05:22 PM
allrotor93's Avatar
can you email the map to me. thanks alot.
email
Old Oct 28, 2002 | 06:17 PM
Marshall's Avatar
Does Ed mess with timing? I have a hunch he didn't in the past. What is your timing from peak torque on up?
Old Oct 28, 2002 | 06:36 PM
80-CU.IN.T's Avatar
Congratulations - Very impressive numbers -
Old Oct 28, 2002 | 09:15 PM
Boost Feels Good
Looks good Roy,
The O2 was right at the downpipe past the AR housing. With this info., how do you feel about it on the road?
MARSHALL
My timing maps came from Scott at www.rx7.com (Ari's shop).
Old Oct 28, 2002 | 09:26 PM
Resource's Avatar
Can you somehow post your maps?
