20B Turbo's?
Old Oct 22, 2002 | 02:46 PM
20B Turbo's?
How does adding another rotor to a 13b affect the choice of Turbo's?
I was thinking of fitting a GT40 but i'm not sure if the Turbine AR will be big enough for the Extra flow?
I am aiming for the 500Rwhp mark with a Extended port engine? will the GT40 be enough or would i be better of going for somthing more like a T78?
Thanks.
Old Oct 23, 2002 | 12:36 PM
Kurgan's Avatar
Gaijin Racing
Re: 20B Turbo's?
Thanks.
With an extended port motor, you can get that out of the stock twins...
If you must go single turbo, go with a T-70 or T-72. The T-78 is too small.
Old Oct 24, 2002 | 12:27 PM
Whats the best Turbine AR for a 20B? i know the 13b is about .96-1.15ar but i would expect a 20b to alot higher than that.
Old Oct 25, 2002 | 08:11 PM
RETed's Avatar
You actually drop it down one or two "steps", especially against a divided turbine 13B.
-Ted
Sobr609
20B Forum
Feb 11, 2019 03:19 PM
Jan 11, 2016 04:08 PM
JZW
20B Forum
Aug 18, 2015 08:56 PM
20B Forum
Aug 18, 2015 02:46 PM
