Street ports
Old Oct 22, 2002 | 01:36 AM
Fd3BOOST's Avatar
Recovering Milkaholic
Street ports
Ok I am knee deep in my rebuild and I just got the front housing exhaust port opened up, problem is the rotary bits I got from Ace hardware didn't last to long (as if I should be surprised) So I will have to pick up some carbide tipped bits. Anyone know of a good source fpor them? I was just gonna do sears.com but can anyone think of anything else? Also I was curious how many of you do your own porting and what kind of experiences you had doing so? Any thing that maybe you would like me to steer clear of that you think maybe I don't know? I always like to hear other peoples advice. Oh lastly what about the Atkins 2 piece 2mm apex seals? Anyone use these?
Old Oct 22, 2002 | 01:50 AM
RICE RACING's Avatar
Porting is quite satisfying the only concerns are the dangers associated (bits in your eyes!).
On the tools, I have a set of bits that have done quite a few engines, when you are doing the Aluminium, use allot of carby cleaner to stop the bits from cloging up, the only thing that will realy wear them out is the rotor housing surface and sleeve's.
Take your time and remember to be carefull !
Old Oct 22, 2002 | 02:51 PM
I found that the higher the air pressure to the die grinder the better. I started with 80 psi and ended up at 120 which cuts like butter. I also used some cutting tool wax from a machine shop. Good luck.
Old Oct 22, 2002 | 06:22 PM
Rx7carl's Avatar
Airflow is my life
Get them from mcmaster and carr. Good prices, super fast shipping! They got all the stuff on their site.
Old Oct 22, 2002 | 09:12 PM
Fd3BOOST's Avatar
Thanks I'll try McMaster.
Old Oct 22, 2002 | 09:14 PM
Fd3BOOST's Avatar
How bad will my boost creep be on my stock twins with the exhaust ports opened up? What would you suggest to controll the creep? Restrictor pill/valve in the vac line? Any suggestions or thoughts?
Old Oct 22, 2002 | 09:45 PM
93 R1's Avatar
Non sequential and full exhaust. Manual boost controller. Thats what I got.
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
Ian_D
Oct 14, 2015 12:31 PM
josef 91 vert
14
Sep 17, 2015 09:22 PM
