Shielded WG hoses
Old Oct 21, 2002 | 12:57 PM
es's Avatar
es
Shielded WG hoses
Would somebody please tell me where to get shielded wastegate hose from?
Old Oct 21, 2002 | 01:27 PM
rx7tt95's Avatar
Photo Diety
Are you referring to something like the Fire Jacket from Aeroquip? It's an insulated fireproof sheath that fits over your existing lines. Try www.bakerprecision.com
Michel
Old Oct 21, 2002 | 02:19 PM
1point3liter's Avatar
Twin Turbo LSX
Eric,
Don't you have to have a wastegate first?? jk
I found an Aeroquip dealer on the westside. They probably have what you are looking for. I believe they are open till 12pm on saturdays. If you want to head over there let me know. JOAT off wells Rd is an Earl's dealer. They probably have something that will work also.
Old Oct 21, 2002 | 03:26 PM
nocab72's Avatar
03 Cobra Killer
You can get vaccum hose covered in braided stainless steel pretty cheap, I think I got 6 feet for about $14 at a local performance shop called JEGS. It isn't Earl's, but it looks just like it...
It's what you see here going into my intercooler pipe, then back to the boost controller solenoid and wastegate. (yes, I need to replace that plastic T)
K
Old Oct 21, 2002 | 08:33 PM
007007's Avatar
i have seen guys bend up brake line to get past the really hot areas and then just use vacuum hose on the ends. Looks very neat and avoids burning up lines. By the way it is a good idea to flare the ends. It is a bit more work but worth the effort.
Old Oct 21, 2002 | 10:51 PM
rx7tt95's Avatar
Photo Diety
Stainless hose is not heat resistant. It'll transfer the heat quite nicely and melt the inner rubber/teflon, whatever is in there.
Michel
Old Oct 22, 2002 | 12:04 AM
vosko's Avatar
Just Call Me Terminator!
my blitz sbc-id came with that stuff....
Old Oct 22, 2002 | 04:11 AM
maxcooper's Avatar
WWFSMD
How about some cheap 1/4" aluminum tubing from the hardware store? It's like $1 a foot or something like that. Use a flare tool and a tubing bender (or the railing on your deck, a hammer handle, baseball bat...) to shape it.
-Max
Old Oct 22, 2002 | 10:57 AM
sub-zero's Avatar
http://www.bakerprecision.com/insulat.htm
Old Oct 22, 2002 | 08:34 PM
Jetlag's Avatar
I just finished installing my EVC and I used Earl's Fire Jacket to protect my Baker's vacuum hose. This stuff is great, it's very flexible and durable. I'll eventually do a Home Depot hard line wrap with the FireJactet.
Oh, I also used it to wrap the ABS line, since its soo close to the hot *** turbo.
Old Oct 23, 2002 | 08:14 AM
es's Avatar
es
Thanks Jetlag and everybody else for the great ideas.
Eric.
Old Oct 23, 2002 | 09:11 AM
es's Avatar
es
Hey Jetlag, where can I get that "Fire Jacket" from? I checked Baker, Summet & Jegs but found nothing.
Old Oct 23, 2002 | 09:47 AM
rx7tt95's Avatar
Photo Diety
Go to Sub-Zero's link again and scroll down. They spell it FyreJacket and it comes in silver and orange. Not the greatest choice in colors, LOL.
Michel
Old Oct 23, 2002 | 09:57 AM
Mr. Stock's Avatar
1993 RX7 R1
-Max
I would think that stainless steel line would be better than aluminum, although a bit pricier.
You can get stainless steel lines here.Inline Tube
Old Oct 23, 2002 | 10:10 AM
Twin Turbo LSX
Is it possible for heat to travel through the stainless line and effect the inner tubing? I'm planning on shielding my braided lines around the turbo and exhaust area.
Old Oct 23, 2002 | 07:56 PM
Jetlag's Avatar
es, I got the FireJacket from Earl's www.earlsperformance.com. I used the 1/2" orange F/J which fits perfectly.
