oil line banjo bolt
Old Oct 9, 2002 | 12:11 AM
rx233's Avatar
oil line banjo bolt
what size it the oil banjo bolt size because i need to know to run a stainless steel -4 line from it can someone help
Old Oct 9, 2002 | 03:42 AM
maxcooper's Avatar
WWFSMD
What banjo bolt? Turbo, engine, where?
-Max
Old Oct 9, 2002 | 10:07 AM
rx233's Avatar
the one that feeds oil to the turbo on the engine
Old Oct 9, 2002 | 06:25 PM
maxcooper's Avatar
WWFSMD
Do you have an FC or FD? If it is an FD, there are two banjo bolts -- one on each turbo. I don't know the size, but is that what you are looking for? Do you want to make a new line or something? The stock setup has a pipe that has a threaded inlet and the two banjo outlets.
-Max
Old Oct 9, 2002 | 06:38 PM
setzep's Avatar
yeah, what are you asking about and which engine. The T2 engines have a smaller banjo while teh FD and cosmo engines have a larger on the front plate
Old Oct 9, 2002 | 07:57 PM
Bacon's Avatar
IRS 4 Life
anyone know the thread for the fd...either where it banjos to the block or where the line goes into the turbo? ive been trying to find thread size/ pitch for a while
thanks
Old Oct 9, 2002 | 09:49 PM
rx233's Avatar
the one on a t2 front plate close to the oil filler
Old Oct 10, 2002 | 09:15 PM
turbostreetfighter's Avatar
the TPI ( thread per inch) is the same on the FD block as a 1/4-NPT fitting!! if you use a 1/4-NPT to -4 male JIC straight fitting and gasoline application pipe tape it will not leak and then you can run a custom line to feed your turbo with no fear of leaking!!
Old Oct 10, 2002 | 09:56 PM
fastrotaries's Avatar
W. TX chirpin Monkey
you can use that banjo bolt and get an Aeroquip banjo fitting to run the line to where ever it needs to go. I'm assuming that you got an aftermarket turbo? This is what i did, and works well.
FD7KiD
15
Feb 26, 2021 10:12 PM
BLK 93
Aug 19, 2015 03:47 AM
FD7KiD
Aug 17, 2015 11:50 PM
