engine question
Old Oct 8, 2002 | 02:28 PM
ULTIMATERX7's Avatar
engine question
When you get your motor ported does your vac at idle go down...My stock motor had 14 psi of vac and my new ported motor has 10-12 psi. I only have 1200 miles on it. Gary
Old Oct 8, 2002 | 04:29 PM
rotarygod's Avatar
Rotors still spinning
If you increased port overlap (which you most likely did do) then yes it will go down some.
Old Oct 8, 2002 | 04:42 PM
rynberg's Avatar
Yes, a streetport will lower idle vacuum. BTW, both of your numbers are very low. 14" for a stock car indicates a problem. 10"-12" either indicates a very large port or a problem.
elfking
Aug 19, 2015 09:48 PM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
