How can you tell if your A/C has been retrofitted?
Old Oct 7, 2002 | 03:51 PM
kmaot's Avatar
Question How can you tell if your A/C has been retrofitted?
Are there any visible cues??
Old Oct 7, 2002 | 04:04 PM
maxpesce's Avatar
Ex fd *****
The person that did the retrofit should have put a tag on the line near the fill/purge valves labled "134r" if not it probably hasn't been done. or at least it wasn't done by a professional AC Tech.
phlanigan's Avatar
They should have put a sticker on the underside of the hood. Also, the r134 system uses a larger valve system, so you can check to see whether the AC valves near the turbos have new valves screwed on top of the old ones.
Old Oct 7, 2002 | 04:07 PM
kmaot's Avatar
I am going to look. Thanks.
Old Oct 7, 2002 | 05:55 PM
kmaot's Avatar
Hmmmm...anyone have a picture? Or a diagram? Feel a bit lost.
I am looking but see only a mass of lines and hoses.
Old Oct 7, 2002 | 07:40 PM
bajaman's Avatar
Constant threat
Here ya go! See the black caps on the ports? There is a high and a low pressure line. The bigger line is always the low pressure. Retrofit 134A kits almost always use a "quick connect" type of connector where R-12 has the screw on style.
Coochas
44
Nov 5, 2019 11:08 PM
Turblown
Sep 30, 2015 05:58 PM
