Seperating the engine and tranny??
Old Oct 5, 2002 | 10:40 PM
Fd3BOOST's Avatar
Recovering Milkaholic
I just about have this mother pulled out . But I can't seem to seperate the engine from the tranny. I am not exactly sure why the Wedge collar and wire ring will not seperate. Any suggestions??? Quick response please!!!
Old Oct 5, 2002 | 11:38 PM
Fd3BOOST's Avatar
Come on guys no one has pulle dtheir engine before??
Why won't my input shaft come out? I can't seem to get the clutch release bearing to come off. Is there a trick that I am missing???
Old Oct 6, 2002 | 12:13 AM
Fd3BOOST's Avatar
I see this forum no longer functions. The 3rd gen forum is basically a big ******* lounge act now.
this should be a place for tech support on 3rd gens and I see **** like"I just wenty single" and "my firts time at the track" and even threads about rims>? wtf ??
Mods are you guys asleep at the wheel or what? There are forums for all these other threads and should be placed accordingly.
Old Oct 6, 2002 | 12:17 AM
lane_change's Avatar
It has begun
Take a big ******* screwdriver and pry like hell through the service hole.
If that doesn't work then start to loosen the clutch bolts one at a time until you have htem all somewhat loose and then it should just pop apart.
Good Luck.
Old Oct 6, 2002 | 12:33 AM
jspecracer7's Avatar
1JZ powered
Good Luck.
That's your best bet Dave....or the BFS or Prybar. I've had better luck with the bolts though.
Old Oct 6, 2002 | 12:50 AM
1JZ powered
Dave,
Did you pull both the engine and tranny apart at the same time? If you have access to a lift, that's what I would do. If not, then proceed as planned.
Old Oct 6, 2002 | 12:59 AM
spooledUP7's Avatar
There and back again
Good Luck.
That's basically what the shop manual says, only without the ******* screwdriver discription. I had to do the latter when I removed mine.
I used a ******* open ended wrench intead.
Old Oct 6, 2002 | 02:04 AM
Fd3BOOST's Avatar
Yea I figured that I was just not man handling it enough.
I'll get under it again tomorrow and pry like a sonofabitch. Thanks for the replies fellas. Nice to see someone willing to help.
Old Oct 6, 2002 | 02:29 AM
Wargasm's Avatar
Weird Cat Man
Dave,
This is what I do, makes it real easy...
Remove the two (or is it 3?) bolts holding the clutch slave to the trans and pull it out at least partially so that it's not right up against the fork any longer.
Remove BOTH cover plates (one on bottom, easy to see; one up near the clutch slave, harder to see).
Now reach into the cover plate near the clutch slave and pull on the fork so that it forces the wedge collar end in towards the engine. Now, holding that there, take a large screwdriver and put it in through the bottom inspection hole and hold the collar part against the pressure plate snugly. Now, release the hold on the slave end.
What should happen is that the fork will pull back away from the engine, but since you still have your screwdriver in there holding the collar area, it will pull the release bearing out without wedging the wedge collar.
I hope this is an ok explanation. This does NOT take a lot of force at all when you do it right. It's easy to do, but hard to explain Plus, I"m not exactly sober now
Brian
Old Oct 6, 2002 | 11:00 AM
Fd3BOOST's Avatar
Thanks Brian I think I got the jist of that. I will give that a go in a little bit. You could come down today and help me do it After I get It out I am pulling off the bullshit and cracking open the engine.
Do you still have your porting templates? I may need them.
Old Oct 6, 2002 | 06:12 PM
Wargasm's Avatar
Weird Cat Man
Dave,
Did my advice work? How's the engine look? Sorry I couldn't come help today but I already had other plans.
I have my porting templates of course... When are you planning on doing the porting? Maybe you could come over sometime and we could do them together and make a video?
Brian
Old Oct 6, 2002 | 06:54 PM
Fd3BOOST's Avatar
Brian it came right out after removing the six bolts between the clutch and the flywheel. Hold for pics..
Old Oct 6, 2002 | 06:57 PM
Fd3BOOST's Avatar
Old Oct 6, 2002 | 07:01 PM
Fd3BOOST's Avatar
Old Oct 6, 2002 | 07:03 PM
Fd3BOOST's Avatar
Also Leslie and I just bought a new video camera today so we can definitely make a vid of the rebuild.
Old Oct 6, 2002 | 07:24 PM
skunks's Avatar
I'm a CF and poop smith
too bad you did not take video of the engine removal, Does anyone have one of that such as like taking appart all the engine connectors/bolts/lines?
Wasn't someone gonna make a video of that, like the entire process of pulling, rebuilding and putting back in an engine?
sleepydogz
Old School and Other Rotary
Oct 4, 2015 03:46 PM
The Shaolin
Sep 14, 2015 07:50 PM
sYnth.
Aug 19, 2015 06:27 PM
Wicked93gs
Aug 17, 2015 12:14 PM
