Ball Bearing dillema,Wich one to buy: GT 35/40 or Apex RX6??
Old Oct 4, 2002 | 05:40 PM
serge1's Avatar
Greetings
I can't decide wich one to buy. Both are ball bearing
and spool faster at lower RPM compared to the laggy
T78. Any idea on wich one pull harder in the entire powerband??
GT 35/40?
Thanks
Serge
Old Oct 4, 2002 | 07:26 PM
sub-zero's Avatar
Serge try a search in this single turbo forum on the GT 35/40 and You should find lots of info. You should go over to Magnus and see if they will give You a ride in the GT 42 setup and tell us all how that turbo spools.
Steve
Old Oct 4, 2002 | 07:34 PM
Poweraxel's Avatar
this question is easy... the GT35/40 spools just like the RX-6 with a monster top-end... I've had both turbo kits and without a doubt the GT35/40 is the way to go!
good luck!
Old Oct 4, 2002 | 08:11 PM
serge1's Avatar
good luck!
Thanks a lot!
Serge
Old Oct 4, 2002 | 08:35 PM
ErnieT's Avatar
Living life 9 seconds at a time
Serge,
I wouldn't go with the Apexi. It doesn't make much more than stock twins, if at all. Good for road racing or auto-x, but thats about it. Go for the GT35/40.......
Old Oct 5, 2002 | 10:13 PM
Mld>7's Avatar
I Post Mad Quick Yo!
just wondering but do they spoolup the same too or is one slightly faster than the other?
Old Oct 5, 2002 | 10:44 PM
1FooknTiteFD's Avatar
Ghost Ride the Whip
lag is overrated. If I could do it over again, I would get the GT35/40 or an even bigger turbo
Old Oct 5, 2002 | 11:21 PM
nocab72's Avatar
03 Cobra Killer
I'm very happy with my GT35/40 kit. It damn near out spools the stock twins > 3500rpm with loads more top end (even untuned, but I'm working on that.)
K
Old Oct 7, 2002 | 02:29 AM
yodaddy's Avatar
Does anyone know what rpm's the rx6 spools up at. also is it true that they have a rx6 kit that lets you keep the airpump?
ls1swap
Jun 3, 2024 03:25 PM
Snook
Oct 8, 2015 10:09 PM
