Thermo-wraps to help spool-up
Old Oct 2, 2002 | 03:37 PM
Lost Time's Avatar
Chimera Driver
Who has wrapped their downpipes with some kind of thermo-wrap in an attempt to help spoolup? Do you have any figures on how much it helped; 500rpms, 750rpms, etc.? Any quantitative info you can provide will be helpful.
Old Oct 2, 2002 | 04:34 PM
Kurgan's Avatar
Gaijin Racing
This is a huge topic open for GREAT debates... almost as bad as the 2mm vs. 3mm seals
Anyhow, I have had my downpipe on my 13bt with 60-1 wrapped and unwrapped. It didn't make ANY noticeable difference either way.
When you wrap a downpipe, you hold heat in, and usully moisture... so, your downpipe was about half the life it normally would. Unless you use Stainless Steel... in that case, i've never personally seen a SS downpipe wrapped.
My advice (if its not SS), just get it ceramic coated so it lasts longer... don't futz with the heat wrap.
Old Oct 2, 2002 | 04:51 PM
duboisr's Avatar
to improve spool up you need to wrap things before the turbo and the turbo to keep the heat in to increase the heat effect on the wheel , after the turbo is of no use to spin the wheel.
Old Oct 2, 2002 | 06:32 PM
AJatx's Avatar
With a rotary, you'll probably shorten the life of the exhaust manifold if you wrap it.
J
AdrianE
May 31, 2008 02:19 PM
Liquid Anarchy
May 14, 2003 02:03 AM
Bluem
Oct 1, 2002 08:10 AM
